I wasn’t really sure where to put this, but beginners seemed most appropriate.
I have always found handling small screws / bolts and nuts fiddly.
I wondered how others cope with very small screws and nuts?
I read in EIM about making tools to make the handling of M1.6 cap screws and nuts easier. They were being used as temporary fixings prior to 1/16 ” rivets. Basically an Allen key offcut held in a pin vice, the screw heing held by a piece of plastic tube on a short guide to feed the Allen key into its intended home. The nut being held by a BA capscrew in a pin vice acting as socket. It seemed a good if complex solution.
This got me thinking that a similar approach might work for hex head screws. i.e.grip the hex head in a pin chuck, much better than the fine nose pliers that I have used in the past. it would be easy to line up the screws in a row of generous clearance holes in some scrap material, hardwood or plastic for example, making it easy to grab them in a pin vice. i have tried gripping one as an experiment and it worked fine. Haven’t tried but it might also work for nuts, not as confident here and not tried. but if the grip is OK a row of pins hammed in to say hardwood, cropped to just above the nut height could be used as a temporary home whilst the nuts are inserted in the pin vice. For fiddly spaces the pinvices could be modified, for example shortened and a side handle added.
Since thinking about this I haven’t really had time in the workshop to try it out.
i did buy a cheap set, £3, of pin vices. Hoping that the jaws might be soft enough to modify with a needle file if needed.
having not used metric screws below M2 I hadn’t realised that a standard metric set of nut spinners has no 3.2 included so is useless for M1.6. i guess that you are expected to have Imperial as well and use 1/8″.
Has anyone done anything similar or have a better system.
