My shop is 6'9" x 10'9" external, with 19 mm cladding on 50 mm frames with 12 mm lining, on three walls The door end,carrying a fire door is 100 mm thick. 8' high at the front, 7'6" at the rear.
No windows, for security, and would be covered by the shelves, anyway!
The firedoor has a 6 lever lock, and hinge bolts.
The roof is 12 mm ply on both faces of the 50 mm frames. All the voids are filled with glass fibre
Originally, the roof was felted, but is now covered with a rubber sheet.
The floor is 18 mm ply on 8 x 2 frames.
being in temperate climate, a 2 Kw fan heater soon makes it cosy, and the thermostat shuts it down in less than 15 minutes. After that it runs for short periods.
The small walking area of the floor is covered with raised plastic mats. (Good insulation and for storing swarf ready for twice yearly cleansing! )
HTH
