I've acquired some Mamod drive-belt (the screw-together kind) for the governor on my Lady Stephanie, to replace the elastic band used currently. I have no idea of what length of belt I need, so how much tension should there be on the band once it's fitted ?
Not very much, but of course depends on the torque you are trying to transmit/overcome. However it's easy to start slack and snip bit by bit off the female end before re-attaching the (tapered) male end
Thanks for the info. I have at least 1/2" jockey-wheel adjustment on a length of about 5" – will it be sufficient to make it fit closely but not stretch, and use that adjustment to get the tension right ?
