Makita LS1013 compound mitre saw – blade issue
Home Forums Manual machine tools Makita LS1013 compound mitre saw – blade issue
  • #574400
    Jon Harrison 3
      @jonharrison3
      I've a nice Makita chop saw which has been really good over the years.
      Just recently the blade centre bolt has started loosening off which is far from ideal. Obviously a LH bolt tightened up really well but it will still unwind after a few cuts. I could see that may just occur if the blade came to a dead stop after a cut, but it doesn't.
      Tends only to do small cuts and softish timber. No prolonged stressing as would be in an Oak beam.
      Any thoughts on the cause or a good fix? PTFE threads?
      Jon Harrison 3
        @jonharrison3
        #574404
        clogs
          @clogs
          that shouldn't happen EVER……
          make sure the blade and backing washers are clean and free from dust n stuff…….
          I'm 72 and in all my years I have never had one of those bolts come loose……
          I've had em when I needed an air gun to get em off tho…..
          if all is well u can use a little thread lock compound, more like screw lock…..it's a weak grade…..
          but really should not be nec…..
          #574407
          ega
            @ega
            I wonder whether a heavier bolt would help so that you get more self-tightening on start-up.
            #574415
            Speedy Builder5
              @speedybuilder5
              "Any thoughts on the cause or a good fix? PTFE threads?"
              Certainly not PTFE as that is a lubricant.
              Bob
              #574416
              John Haine
                @johnhaine32865
                Posted by Jon Harrison 3 on 06/12/2021 10:08:20:
                Maybe have a sacrificial oak beam to tighten it up?
                #574422
                Jon Harrison 3
                  @jonharrison3
                  I've had it maybe 8+ years with no issues.
                  Typically used it this morning for about 30 minutes without problem.
                  All very strange!
                  #574423
                    Just recently the blade centre bolt has started loosening off …
                    … do small cuts and softish timber. No prolonged stressing as would be in an Oak beam.
                    Vibration is an excellent way of loosening bolts. What is the 'softish timber'? Possibly it's a mix of hard and soft fibres that vibrate the bolt, whilst 'small cuts' don't put enough force on the LH bolt to re-tighten it.
                    Are you thinking Nylock rather than PTFE? I'd try thread-locker, or even super-glue.
                    Edited By SillyOldDuffer on 06/12/2021 12:49:49
                    #574427
                    Bill Phinn
                      @billphinn90025
                      This sounds, Jon, like a situation where Nord-Lock washers may help.
                      Just be cautious about buying them from Zoro.
                      EtA: I'm not sure they work on left-hand threads, though. Theoretically they shouldn't, but Nord-Lock doesn't seem to even mention the matter.
                      EtA 2: A bare "The standard assortment is for right-hand thread" is the only reference I've seen in Nord-Lock's promotional material.
                      Edited By Bill Phinn on 06/12/2021 13:31:47
                      #574429
                        I've not had one come loose though I did have the head shear off an Electra Beckum chop saw once, luckily as the blade was down so it just rattled to a stop..
                        As said by clogs make sure its all clean and a low strength thread locker. Also make sure bolt is tightening if you have changed to a thin kerf blade at some time.
                        #574433
                        Dalboy
                          @dalboy
                          In 25 years of working with(as a plant mechanic) chop saws of various makes the only times they have come loose is either operator error by not pinching them up enough(Not hanging on a 6ft pole), not cleaning the mating surfaces when replacing the blade and finally fitting a replacement blade that is made of thinner material to the original in which case can be overcome with two paper washers.
                          The biggest problem is those that are so tight they have been tightened by the local gorilla on site
                          Edited By Derek Lane on 06/12/2021 13:56:45
                          #574442
                          Tony Pratt 1
                            @tonypratt1
                            Strangely the force from cutting should tighten the nut.
                            P.S. What is wrong with the poxy spell checker?
                            Tony
                            #574444
                            Samsaranda
                              @samsaranda
                              I would suspect that you are suffering a vibration problem, that could easily be the cause; has the saw started vibrating more than usual and is there evidence of any problems, e.g. bearings worn which could be a source of vibration. Dave W
                              #574453
                                Posted by Samsaranda on 06/12/2021 15:32:59:
                                Adding to that ^^^
                                I would suggest checking the condition of the saw-teeth … a blunt or chipped tooth can be enough to induce excessive blade vibration.
                                Gordon Tarling
                                  @gordontarling37126
                                  Have you by any chance replaced the blade recently? I only ask because my plunge saw started doing the same thing after I fitted a new blade – discovered the new blade was a smidge thinner than the old one, thus not tightening fully.
                                  G.
                                  #574719
                                  oldvelo
                                    @oldvelo
                                    Are you using a reducng bush in the blade that is thicker than the blade.
                                    A thinner blade may need to have the recess the clamping washer to be machined a little deeper.
                                    Replace the clamp bolt with a brand new one plus flat washer and star washer.
                                    Clean the clamping and blade oil and grease. Silcone lubricant spray if used on the saw is often the cause of the blade clamp slipping loose.
