Russel Yes Sodium Ferrocyanide does give off Hydrogen Cyanide (HCN) at high temperatures but only if water is present. Kasenit contained both Barium Carbonate and something else. These formed a coating on the metal. This was done by using the water of crystallisation which boiled off long before the Ferrocynide started to disintegrate into HCN.
If you want to see this get some Epson salts (Magnesiun Sulphate) and warm them up. You can also see the same effect with Borasic Acid (borasic powder) you get from the chemists and use as flux –both of these contain water in their crystals-
Neither the makers of Kasenit or any other company would want to be involved in a Coroner’s Inquest so their products were safe for normal use. I dare say if you ate a ½ kilo or so you would need a few hours with the undertaker.
The lethal dose of HCN can be as low as 1.5 mg/kg of body weight. HCN is also lighter than air. This is why it is not used in military chemical weapons. I weigh somewhere over 75 kgs so to kill me you would require a minimum of 90mg of the stuff that is a large amount as a gas in air. It took upwards of 1/4 hour to kill all the folk in an Auschwitz gas chamber. Elfinsafety do not care they see their job is to keep you safe and damn the consequences
Handrudolph Barium Carbonate is used as a cheap glaze in the ceramics industry, glass making, and in rat poison so go and see a potter, borosilicate glass maker they may give you the few grams that you need
I think we had best leave it at that
P.S Calcium Carbonate can be used in place of Barium Carbonate as an accelerator but it is not as reactive.
Rdgs
Dick
Edited By Richard Parsons on 21/03/2012 13:01:25
