Making steel channel
Home Forums Workshop Techniques Making steel channel
  • #232302
    Mark P.
      @markp
      Hi all, I need to make 2 pices of mild steel channel 44x25x4x300mm long if I machine it from 25x50mm bright flat will I end up with a twisted mess?
      Regards Mark P.
      Mark P.
        @markp
        #232305
          Very probably.
          I think it would need some Stress-Relief first … a night in the embers of a fire might help.
            Cut down two bits of angle and weld them into a U. If you like making swarf then get black flat bar as its less likely to move. I have used this e-bay seller a few times for black bar and angle, also does 50x25x5 chanel if you could get away with 48mm x 24 x 4 after a skim
            Edited By JasonB on 29/03/2016 17:42:12
            #232327
            Mark P.
              @markp
              Thanks for the replies just as I thought a mangled mess! Will have a look at that supplier Jason. If all fails I will try black bar.
              Regards Mark P.
