Making retaining pins
Home Forums Workshop Techniques Making retaining pins
Viewing 15 posts - 1 through 15 (of 15 total)
  • #15559
    James Garvin
      @jamesgarvin12709
      James Garvin
        @jamesgarvin12709
        Can someone explain to me how to make small Retaining Pins (R clips). They are for a modication project – 10mm long to fit 3mm shaft. Where can I buy the material. All the better if I can buy them ready made up.
        #84094
        James Garvin
          @jamesgarvin12709
          I’ve decided to give it a shot anyhow – ordered 1mm steel wire and a wire bender. However any tips are welcome.
          #84099
            Or slightly shorter than Johns link on e-bay I, ve got a couple the same 16mm long but can’t recall where thay came from
            I doubt a wire bender will be much use, better with a few vertical pins sticking out of a block of metal and bend round them
            J
            Edited By JasonB on 07/02/2012 08:44:12
            #84101
            James Garvin
              @jamesgarvin12709
              16 mm should be fine. I am trying to modify a Radionic bolt together electronic kit for quicker and more reliable circuits. I think I need a large spring washer or spring strip to take up the slack to make electrical contact. Any suggestions.
              #84104
              James Garvin
                @jamesgarvin12709
                I was thinking, I dont need R clips after all. All I need are short pieces of solid wire with a right angle. The bender will make a good job of that. Would a clock spring cut up and drilled take up the slack of the screws.
                #84105
                  Cutting and drilling clock springs is not easy as the have been heat treated maybe a small spring washer
                  #84110
                  James Garvin
                    @jamesgarvin12709
                    Yes I was afraid of that. By the way is there an alternate to using a pin. I may be able to drill the 6BA screws using a milling machine but I have so many to do for each component holder. Did I see something once which you sqeeze to slip over threads and it grips when released. I wonder what they are called
                    #84114
                      I’ve not seen them for threads but you can get star locks to go on the end of shafts which would probably grip the thread also available from Model Fixings or what about nylock nuts
                      #84121
                      James Garvin
                        @jamesgarvin12709
                        No its not that. I’m trying to get away from bolts – slow to put on and a loose one causes bad electrical contact. A pin would be quicker and may have to do. I seem to recall it was like a spring washer with 2 jaws which opened when you sqeezed. Thanks for your time – you have a very impressive posting record.
                        #84123
                        AndyP
                          @andyp13730
                          James,
                          Sounds like a jewellers butterfly clutch as used on lapel pins etc. I haven’t seen them in a size that would fit a 6ba stud though, more like 2mm maximum. Ggogle will show you pictures.
                          There are stamped steel “washers” with 2 or more inward facing teeth, seem to remember them holding the wheels on my grand daughters toy pram at Christmas, haven’t the faintest idea of the proper name for them though, sorry.
                          Andy
                          #84124
                            Andy those are the starlocks I mentioned above though your pram probably had the ones with chrome dome caps.
                            J
                            #84127
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              The ones you want are called E type circlips and are widely used in electro-mechanical equipment especially things like printers and photocopiers .
                              Probably available from RS or Farnell .
                              MW
                              Edited By MICHAEL WILLIAMS on 07/02/2012 19:35:11
                              #84133
                              AndyP
                                @andyp13730
                                Dem’s em Jason, well done, Silver Cross pram – made in China
                                I don’t think those, my butterfly clutch, or any of the circlips would provide a positive pressure along the pin though, merely resist pushing off by which time the contact may be broken ?
                                Andy
                                #84141
                                MICHAEL WILLIAMS
                                  R clips and multiple variants here :
                                  MikeW
                                  Edited By MICHAEL WILLIAMS on 07/02/2012 23:08:20
