Making Reamers particularly tapered reamers
Home Forums Workshop Tools and Tooling Making Reamers particularly tapered reamers
  • #92083
    martin perman 1
      @martinperman1
      Gentlemen,
      A friend of mine is making a new arm for a flick magneto and he has to put a tapered hole in its centre to match the tapered shaft on the magneto, would it be possible to make a hand reamer to cut the taper after he has step drilled the hole.
      Thanks in anticipation,
      Martin P
      martin perman 1
        @martinperman1
        #92085
        Swarf, Mostly!
          @swarfmostly
          Hi there, Martin,
          I suggest that you research tapered D-bits.
          Best regards,
          Swarf, Mostly!
          #92088
          Ady1
            @ady1
            I think it was Sparey who had some home made d-bit reamers in his book
            Cut a silver steel bar to the required size then harden
            #92089
            PekkaNF
              @pekkanf
              Would a google with "D-bit reamer", "D taper reamer" or "D bit chambering reamer" help?
              I ocassionally stumble upon on D-bit type taper reamer instructions, but can't remember bookmarkking any right away.
              I have made several too from silversteel/dil rod and they seem to work reasonably well, require quite a bit effort to use though.
              There is one rather compilicated, but good method:
              Pekka
              #92090
              martin perman 1
                @martinperman1
                Gentlemen,
                Thank you very much for your help, I shall find a piece of silver steel of the correct size and make the reamer for him.
                Martin P
                #92092
                Ramon Wilson
                  @ramonwilson3
                  Martin, I have made many tapered 'D bit' reamers over the years all of which have produced good holes and surface finish mainly in steel but also brass and aluminium.
                  The big problem with tapers is that to be effective they have to match the corresponding part exactly and this is usually achieved by making sure the hole is done at the same setting as the cutter without moving the topslide.
                  When this can't be done ie in your case – if its possible you need the magneto shaft as you do it. Turn a tapered hole in a piece of scrap (I usually use brass) to match the shaft as best you can and then check the shaft in this using engineers blue to see where it fits – slightly moving the topslide and recutting if required to improve the fit until it's satisfactory and mating its full length. It's surprising how little it has to be moved to make quite a big difference in fit. Once you have the taper right you can then proceed to make the cutter reasonably confident that it will match the shaft
                  Hope this helps – Ramon
                  #92094
                  martin perman 1
                    @martinperman1
                    Ramon,
                    Thanks for that, I have a similar magneto that I'm going to use as my template.
                    Martin P
                    #92095
                    Gordon W
                      @gordonw
                      If you can set the shaft between centers you can then set the topslide with a dial gauge, should be spot on. Difficulty I have is cutting down to exact center without a mill.
                      #92115
                      Richard Parsons
                        @richardparsons61721
                        Actually I would measure the taper and then do a bit of research in the books/Google. I will bet you a single knob of dog biscuit to a pinch of snuff that the thing is a known standard. I do not know what the size is but manufacturers always to use ‘standard tooling’ if they can.
                        There is another way. Set your compound (or taper attachment if you have one) as Gordon W describes. Turn a plain taper next put a small end mill in your tool post milling attachment (mine is the headstock from my first lathe a Unimat SL) I was planning to ft an overhead shaft system but the builder fitted a cavity ceiling when he was told not to. He did so because he said a plain concrete ceiling would not look nice.
                        With the mill make 6 passes down the work piece so that you have now a 6 sides broach. Harden and lap in the usual way.
                        Rdgs
                        Dick
                        #92126
                        Gordon W
                          @gordonw
                          From memory:- the taper will be 1 in 6 or 1 in 7.
