Here is what I do.
Make the liner first so you can use that to gauge the OD of the rings.
Chuck a bit of suitably sized CI bar in the lathe, face off and then turn sufficient length for the 4 rings, a couple of spares and the parting cuts until it just slips into the liner. Open up the hole with various size drills followed by a boring bar until you get the desired wall thickness.
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Zero a thin parting tool against the end of the work, feed along the lathe to get the required width of ring and part off. Repeat by feeding along the ring width plus the parting tool width until you have enough rings. It helps to put a bit of wire or one of those angled scribers in the tailstock chuck to catch the rings as they drop off.
I find that a pair of end cutters will split the rings OK, even quite thick/wide ones. Use the cutters on the two edges hot the inside & outside faces. The black lines are where the ring has fractured not cuts.
Next spread the rings apart, some methods describe fancy jigs but I just pop a bit of scrap flat bar between the ends, about 4mm thickness per 1" dia seems to work OK for me. Not having an oven I just lay the spread rings on the hearth and heat with a blowtorch. Keep the heat even otherwise you will get egg shaped rings if one small area get hot first. I heat to red heat and hold it there for 3-4 mins then allow to cool slowly. The packer will now be loose as the ring will have taken the "set".
Lay a bit of wet and dry on a flat surface and rub the edges of the rings on that to clean them up and remove any burrs and scale from heating. To gap the rings hold them on the edge of the bench with the gap hanging over the edge then pinch the two ends together onto a needle file which can be worked up and down. To test the fit put the ring into the bore and use the piston to push it in so it is not angled in the bore, test the gap with feeler gauges, I go for about 0.002 per 1" bore.
Finally fit the rings to the piston and off you go. Ring grooves about 0.005" deeper than the ring thickness and 0.001" wider than ring width. This pic will also answer your other question![wink 2 wink 2](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
If all else fails revert to O rings like on the drawing![smile p smile p](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Edited By JasonB on 17/04/2016 14:02:49
