Making new tappet adjusters.
Home Forums Workshop Techniques Making new tappet adjusters.
  • #16427
    Andrew Tinsley
      @andrewtinsley63637
      Andrew Tinsley
        @andrewtinsley63637
        The tappet adjusters (basically a threaded rod and adjusting nut) need replacing.
        I have sourced some long, high tensile, 1/4" UNF grub screws and grade 5 nuts. The grub screws have a hex slot rather than a screwdriver slot which is easier when it comes to adjustment.
        It is the other end of the grub screw that presents a small problem. I need to make them hemispherical to fit into the top of the push rod.. I don't have a ball turning device and apart from the use of warding files, I don't have a good idea of how to do the job!
        I am sure I am missing a trick here or overthinking the solution, so any suggestions? Otherwise it will be files and Mk 1 eyeball.
        Andrew.
        #634184
        peak4
          @peak4
          Maybe an HSS form tool and a basic lantern chuck in the lathe
          If you can find one the correct diameter, you could even use a woodworker's carbide tipped router cutter in the toolpost, as the form would then be ready ground.
          Bill
          #634211
          noel shelley
            @noelshelley55608
            Bill has it ! A form tool at that size, ground from HSS. Rough out screw end to 45* to get rid of the bulk then finish with the form tool. Noel
            #634217
            Andrew Tinsley
              @andrewtinsley63637
              Now why didn't I think of that. Thanks Bill and Noel. I have this vision of form tools as being for much larger jobs.
              Thanks again,
              Andrew.
              #634219
              Roger Woollett
                @rogerwoollett53105
                How about a ball ended endmill in the drill chuck?
                #634227
                Andrew Tinsley
                  @andrewtinsley63637
                  Probably showing my ignorance, but isn't a ball ended end mill, one that has a ball or hemisphere on the end? I want a ball or hemisphere on the tappet adjuster, not on the cutting tool, or have I totally misunderstood your suggestion?
                  Andrew.
                  #634230
                  Roger Woollett
                    @rogerwoollett53105
                    You are quite right. I was thinking of the end of the push rod.
                    #634246
                    Mike Poole
                      @mikepoole82104
                      I was wondering if a grub screw will be hard enough for a tappet adjuster? They are usually very hard whereas socket headed fasteners are made from material selected and heat treated for toughness. Depending on your application the grub screws may have a shorter than hoped for life. Of course they may last for ever if they are relatively lightly stressed.
                      #634247
                      KEITH BEAUMONT
                        @keithbeaumont45476
                        I have made similar form tools by using silver steel,driling a hole at an angle,to give the wanted radius Grind away to leave half of the drilled hole , harden.Usualy works quite well.
                        Keith
                        #634248
                        Chris Evans 6
                          @chrisevans6
                          I tend to make my tappet adjusters from silver steel and simply harden with a blow torch. Works for me but the old Sloper only does around 300 miles a year.
                          #634259
                          Andrew Tinsley
                            @andrewtinsley63637
                            I thought of using grub screws (with a hex hole) as most of the work has been done. The ones I have ordered are quoted as being high tensile and meeting AINSI B18.3 standard. Anyone know if that spec is suitable for my intended use?
                            Like Chris, the tappet adjusters will get a very easy life in my Petter driven alternator. Used for power cuts only, apart from annoying the neighbours when test running and annoying them even more when there is a power cut.
                            Andrew.
                            Edited By Andrew Tinsley on 19/02/2023 22:34:17
                            #634263
                            Hopper
                              @hopper
                              They might last an hour or two unhardened or maybe a bit more. But they might mess up the ends of your pushrods and fiinish up costing you more money in the long run too. I would buy the correct parts. They take quite a hammering due to the tappet clearance and there is a reason every manufacturer hardens them..
                              #634274
                              John Olsen
                                @johnolsen79199
                                There is a technique for turning small ball shapes which might work for this. You take a piece of silver steel rod a little larger than the ball size, and drill a hole in the end a little smaller than the ball size.Face the end and then harden. Fit the other end into a file handle, and arrange a rest in the tool post close to the job. Having roughly formed the ball end with a 45 degree chamfer, use the hand turning tool to form the ball, moving it around the end of the job so that it can cut. The circular cutting edge on the inside of the hole will form the ball. The outside edge is not a cutting edge and should never contact the job.
                                I've used this technique to form ball ends on tiny handles as small as about 1/8 inch or so. A refinement is if you can manage to face the end back at an angle to give some relief to the cutting edge. This sort of tool will work for a range of sizes, the smallest being the size of the hole.
                                Otherwise, you can make a form tool from gauge plate by drilling a hole the size you want and then cutting away the bits you don't want to leave a half or quarter circle cutting edge.
                                Case hardening should be enough for the tappets for a vintage style of engine.
                                regards
                                Andrew Tinsley
                                  @andrewtinsley63637
                                  Hopper
                                  Unfortunately the tappet adjusters are no longer available to buy, hence making them is the only solution, So you give the home made ones a couple of hours before they ruin the push rods? Goodness knows if the grub screws can be hardened, I wouldn't know where to start looking for AINSI standards.
                                  Looks as though it might be better to go Chris Evans route and make them out of silver steel and harden them? I have never had much luck threading small diameter silver steel, I always finish up with a very ragged thread. Doesn't matter if I use a die or screw cut, the silver steel is good quality stuff (Coventry Grinders).
                                  Andrew.
                                  #634302
                                  Hopper
                                    @hopper
                                    I don't know how long they would last for sure. The only way to really tell would be to run them for an hour and inspect carefully. May well be all right for occasional emergency gen set use. But I would not expect them to last too long if not hardened.
                                    I don't have trouble threading silver steel but use good quality dies. I don't know if high tensile bolts would have enough carbon in them to harden like silver steel. I think they are more of an alloy steel than high carbon content, but have never looked it up. I am sure it is out there somewhere.
                                    1/4 UNF tappet adjusters from something else might fit? Lister?
                                    #634325
                                    Clive Hartland
                                      @clivehartland94829
                                      The ball ends will have to be polished to match the pushrod cups, case hardening may be the best way .
                                      #634332
                                      duncan webster 1
                                        @duncanwebster1
                                        Allen screws are probably some alloy steel, we need a metallurgist to comment on whether case hardening is a good idea. Above my pay grade.
                                        #634338
                                        Robert Butler
                                          @robertbutler92161
                                          Posted by Andrew Tinsley on 19/02/2023 13:44:33:
                                          Andrew.
                                          Try A series tappet adjusting screws
                                          Robert Butler
                                          #634354
                                          Andrew Tinsley
                                            @andrewtinsley63637
                                            Hello Robert,
                                            Good thinking, but A series tappet adjusters are 7/16" UNF. As I found out long ago!
                                            Thanks,
                                            Andrew.
                                            #634386
                                            bernard towers
                                              @bernardtowers37738
                                              Sorry but 803 A series are 1/4 UNF
                                              #634387
                                              bernard towers
                                                @bernardtowers37738
                                                Andrew I think you have your wires crossed, the spanner size is 7/16 which makes the thread 1/4
                                                #634388
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  Well you live and learn! I have had just about every A series engine except for the 803! These all had 7/16" UNF tappet adjusters!
                                                  Thanks for that Bernard, I should have more success looking for those..
                                                  Andrew.
                                                  #634397
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    Hello Bernard,
                                                    The tappet adjusters on the Petter are 1/4" UNF, checked with measuring the diameter of the adjuster and a thread gauge.
                                                    For the A series tappet, I inadvertently typed 7/16". It should be 5/16" UNF !!!!!! Thanks for correction. The adjusting nut is 7/16" across flats and the very later A series had 1/2" across the flats, adjusting nut.
                                                    Thanks,
                                                    Andrew.
                                                    Edited By Andrew Tinsley on 20/02/2023 21:30:33
                                                    #634492
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      The tappet adjuster screws, and threads in the rockers, on the 803 cc A Series were 1/8 BSP from memory
                                                      1/8 BSP ,is 28 tpi, same pitch as /4 UNF, but different tread form.
                                                      Indeed that is where I inherited the drill and tap from my father., or was he wrong?
                                                      Edited By Howard Lewis on 21/02/2023 15:17:49
                                                      Edited By Howard Lewis on 21/02/2023 15:18:25
