Making Myford tailstock
Home Forums Workshop Tools and Tooling Making Myford tailstock
  • #20535
    V.Tunç Burak
      @v-tuncburak57904
      V.Tunç Burak
        @v-tuncburak57904
        Hi,
        I came across your forum while researching about Myford. I am an industrial product designer.
        I have a workshop on product design, model and prototype in Istanbul/Turkey.
        When I first opened my business, I had a 1959 model myford tri-leva.
        In time, I completely disassembled the lathe, repaired it and painted it.
        I made some additions to the pedestal it is on. I designed and produced a lighting product suitable for its design.
        The only thing missing is the tailstock for the completion of my lathe. I could not find the original tailstock in Turkey.
        I couldn't get it from other countries either.
        As a prototype workshop, I am capable of creating a model of the tailstock.
        I want to make a 3d drawing of the tailstock, produce it on a 3d printer,
        and have it cast with a sand mold. To do what I say; i need technical drawing or 3d model file of original tailstock.
        I would be glad if you help me in this regard.
        I am sharing the photos of my lathe with you.
        Thanks for your help.
        V.Tunç Burak
        Bronze Design Modeling Prototype
        instagram : bronzemodelleme
        Photos
        https://files.fm/u/zydkzm6pa
        #575399
        Brian H
          @brianh50089
          I don't know if this helps;
          https://www.ebay.co.uk/itm/393668757108?hash=item5ba87c8674:g:VHEAAOSwWGBhgVE-
          All the best with your lathe.
          #575406
          peak4
            @peak4
            Hello and welcome, I can't help with a formal drawing unfortunately.
            Nice clean workshop you have there, and certainly probably warmer than mine at the moment.
            All the best
            Bill
            #575437
            Howard Lewis
              @howardlewis46836
              Welcome!
              Tri Leva is not a Myford model type, but a means of changing speed, by using different pulley combination to effect a speed change, rather than doing so by moving the drive belt manually.
              Consequently, we do not know if your machine is a ML7 or a later version.
              You would ,do well to find the Serial Number, and the more expert on here may well be able to tell the model and when it was manufactured..
              You might then be able to find a Tailstock if you post an ad in "Wanted"c on here, in M E W , or try Google. You might find at a machine tool dealer, or on one of the auction sites. They might even be glad to get rid of a loose item like that!
              You need to specify which model it is, and to be safe, look ay the various places, Myford manual, or dealer's pictures to see the correct pattern to suit your machine. The ML 7 Tailstock is not the same as the later models .
              The centre height will be the same, nominally, but the exact pattern and operation may well differ.
              Hope that this is pf some help
              #575443
              Grizzly bear
                @grizzlybear
                #575453
                T.B
                  @t-b-2
                  Looking at the photos , its a Myford ML7 Tri leva
                  It also looks like a long bed version to me and that would explain the Super 7 type cross and top slide which are far superior and where often fitted to long bed ML7's
                  Any Myford 7 series tailstock will fit as the bed dimesions are the same on all models , in fact the Super 7 type tailstock was often fitted to long bed ML7's along with the different top and cross slides as mentioned above so its very likely the missing tailstock was a Super 7 type
                  #575458
                  V8Eng
                    @v8eng
                    I think the Tri-leva attachment could only be fitted to an ML7 lathe.
                    #575459
                    duncan webster 1
                      @duncanwebster1
                      There are several ML7/S7 tailstocks on ebay, prices £150 upwards. Getting postage to Turkey is probably an issue, but you could contact sellers and see what happens
                      #575467
                      Howard Lewis
                        @howardlewis46836
                        A Tailstock, admittedly, used, can be bought either from a machine tool dealer or on E bay, so it would take less time to unpack, fit and align than to print a patterns, and machine the casting and other components.. .
                        Edited By Howard Lewis on 14/12/2021 22:57:27
                        #575642
                        V.Tunç Burak
                          @v-tuncburak57904
                          Thanks so much for your responses. I know about second hand tailstock on sale but I have problem about shipment to Turkey. Beside these problems I want to produce this tailstock. If there is a myford owner among you and has the original tailstock, could you please share with me a photo of it? You have to take photos from the top, bottom, from two sides, in front and behind. And mention the dimention of specific points on the photos. Though I can create a 3d program drawing and generate a model. After I complete the production, I can share it with you. Maybe we can help the people which want to produce it like me.
