I'm in the process of making a 1" Minnie traction engine and there are a few keyways included in the design.
I've got the keyway cutting worked out for my gears as per Mason's book.
The next thing I need to do it cut the slots on the shafts and I don't have a 3/32" milling cutter. Mason's book explains "Making small end cutting slot drills bas been described so many times that it should be unnecessary to detail the procedure here".
Can anyone point me at the design and technique for making a 3/32" slot / end mill?
