Its about the same method I use to fit/press pinions in brass wheels, it works very well but you need a rigid set-up and the parts must be lined-up absolute centered, square and straight and stay that when you press it in, either by the set-up or by a pivot or bush that keeps it centered, otherwise it will find its own way. The profile is not formed but cut, I turn the edge of the pinion I want to press in to get a ring of sharp "cutters". For brass the steel need to be tempered at around 35Rc, if it is softer it will not work, perhaps you can use softer for aluminium but I doubt. Also you will need considereble force, the tailstock of my Myford will not hold on a diameter of around 5mm, the largest diameter I fitted by this method was (I guess, long time ago) 15mm and for that I used a 10ton press. Niko.
Edited By speelwerk on 08/01/2015 23:27:26
Edited By speelwerk on 08/01/2015 23:38:33
