Can I add a few words to the interesting piece by Bob Hayter, pp 140 – 143, ME 4721?
We are told that it is important to position the magnets alternately N up and S up. It is just as important, though, to do the same with the coils. When doing the continuity test, use the compass to check that alternate coils produce a (feeble) N and S as the current flows. Get this wrong and the coil outputs will tend to cancel each other out.
It would also be helpful to know a little about the wire for the coils. What to ask for, and what gauge – and for those in distant parts of the ex-empire, what the gauge means in millimetres. And incidentally, the output contacts should not be marked red and black – this is a convention for DC output.
And finally, please add a note that the output will vary a lot with the driven speed, and will be no use for many electrical tasks. In fact, it would help if a few words on rectification and voltage control could be added – just in case anyone wanted to use it for charging batteries, or driving DC motors, or small LEDs.
Tim
