Making a small plastic fan
Home Forums Workshop Techniques Making a small plastic fan
Viewing 6 posts - 26 through 31 (of 31 total)
  • #296184
    John Rudd
      @johnrudd16576
      image.jpegI have made progress!
      I made a silicone mold based on an original fan, then molded a new fan from the mold…..
      Good result I'd say…..the fan pictured requires cleaning up, machining to size and then balancing( another challenge!)image.jpeg
      Russell Eberhardt
        @russelleberhardt48058
        Looking good John.
        What material did you use?
        Russell
        #296202
        John Rudd
          @johnrudd16576
          I used polyurethane resin/activator for casting the fan…..
          Demold time was around30-40 mins. Allowance made for a bit more time to fully cure/harden. I finished off the fan in the lathe, turned to diameter and thickness…
          The fan is now installed in the drill and runs like a good'un….
          I'm very pleased/surprised at how well it has turned out, the original fan had the part number TPD6 on its surface, the mold has picked this up and it has actually transferred to the new casting…..
          I'm now considering adding some fibreglass to strenghten….any thoughts?
          I'd need to be quick whetting it out as the pot life of the resin is minutes!!
          #296203
          Brian Oldford
            @brianoldford70365
            Posted by John Rudd on 03/05/2017 14:42:31:
            Hi John
            I'm glad my suggestion of pulling a silicon mould off an original worked for you. Just out of interest what particular PU resin did you use in the end?
            #296205
            John Rudd
              @johnrudd16576
              Brian,
              I used Mouldcraft A2000L…..
              Reason being, I could get a small quantity for minimal outlay so I could see how it was going to work out….
              Thanks for the initial advice…yes
              #296504
                Well that worked
