Posted by SillyOldDuffer on 06/10/2022 11:07:58:
Posted by Derek Lane on 06/10/2022 09:57:50:
It is not easy for someone to stand in front of a camera and produce a video …- Steve isn't the best person to demonstrate workshop best practice on screen. Nor am I! Ideally anything for public consumption should be peer reviewed before publication because it's extremely hard for people to see their own mistakes.
- Steve uses a bit of scrap that might be an old gib.
- Steve misses the chance to explain the difference between climb and conventional milling – he does both.
- There's another missed opportunity to explain how to choose RPM, the end-mill is spun too fast at one point – Steve says "it is High Speed Steel".
- Lastly a full 2 minutes of a 17 minute video show Steve vacuuming swarf, which should have been chopped down by the editor! And it would be helpful to mention this is a job for a workshop vacuum cleaner, not the Domestic Supremo's brand-new top-of-the-range Dyson!
Hi Dave & thanks for the constructive comments from you.
Just a couple of points. The video was shortish for me, so i did not show some things. When i took the piece of steel from the drawer. The 1st thing i did was ran a file on the corner to check it would machine. I have a Henry vac 110V . Yet to build a vac system, (A job on the board.) Yet the one i used was just an old one donated to me.
Sorry i did say the cutter & the speed i was using but when i sped the vid up to 1000% it blurred out the speech.
The txt was just a joke about HSS. 850rpm. The depth of cut is something i just try. So it would not really help anyone
But i must say all comments you made are taken on board. I thank you for watching the video.
P.S I have posted another pretty unusual one for me of repairing a total write off Motorhome. Did not put a link up as not sure there is a subject that would cover it on here. EDIT. Found vehicle restoration so i have posted it on there.
Regards.
Steve.
Edited By Steviegtr on 06/10/2022 12:43:36
