Making a ring mandrel- jewellery tooling
Home Forums Help and Assistance! (Offered or Wanted) Making a ring mandrel- jewellery tooling
Viewing 25 posts - 1 through 25 (of 47 total)
  • #256725
    OldMetaller
      @oldmetaller
      Good morning everyone, I have just rashly promised my girlfriend that not only will we get engaged, but also that I will MAKE her a ring!
      I have read up on ring-making, and know that I need a ring mandrel. Being a tightwad, I want to make one out of a steel round bar offcut.
      My problem is, I need to know what, in degrees, is the taper I need to cut on the bar, given that the ones I have looked at have a working length of 200mm which tapers from 25mm to 10mm?
      I know that somebody on here will know how to work this out, sadly my skill with numbers is non-existent.
      As a bonus, if somebody could tell me the ID's of the various ring sizes I would be able to groove the mandrel appropriately.
      Over to the vast body of knowledge and information that I know to be present on this forum!
      Thanks in anticipation,
      John.
      OldMetaller
        @oldmetaller
        What is the taper?
        #256729
        Les Jones 1
          @lesjones1
          Hi John,
          If you dig out your maths notes from school from when you were about 13 they should refresh your memory of trigonometry. As the difference in the small and large diameters is 15mm (25 – 15) then the right angle triangle formed between a line perpendicular to the large end that meets the small end will have one side 200mm long and the other 7.5mm long (15/2) . So now you know that the tangent of the angle is 7.5/200 = 0.0375 As you know the tangent you can find the angle from log tables (If they were still used when you wnt to school.) or us a scientific calculator to find the angle. You will find that the angle whose tangent is 0.0375 is 2.15 degrees. This is the angle between the axis and one side. The included angle will be twice this which is 4.3 degrees.
          Les.
          #256730
            The included angle is 4.3degrees so either set your topslide over to 2.15degrees or offset the tailstock which would allow you to cut the taper in one long pass, you will need to offset enough to move the tailstock end of the work 7.5mm closer to you, thats if you need to make a full length one.
            Edited By JasonB on 19/09/2016 08:29:34
            #256737
            JohnF
              @johnf59703
              John, have a look at the link below for sizes, quite a bit of info. Regards John
              not done it yet
                @notdoneityet
                Here is a simple solution to your problem.
                All you need is a ring which already fits her finger. Use it as a comparator. You can then make a short guage at any angle you desire, marking it at the point where her current ring fits.
                #256747
                Chris Evans 6
                  @chrisevans6
                  This brings back memories of making rings from 2 shilling coins. I still have the little jig somewhere that has a vee shape milled in it with a shallow angled dovetail cutter. The coin was then held by hand in the vee and gently hammered to roll the outer so that the writing on the coin was readable from inside the ring. Sizes where taken from a ring that fitted the girl. At the correct inner size the hammering stopped the ring put in the lathe and bored to suit ring size the on a mandrel to form the outer. Polished up they looked nice. Early coins with more silver content where used. One girl I made a ring for had big fingers which meant using a half crown coin to get the size.
                  Good luck with the ring making. Chris.
                  #256748
                  KWIL
                    @kwil
                    #256763
                    Speedy Builder5
                      @speedybuilder5
                      For a one off, use a morse taper. Fingers are tapered, but I never heard of a standard for fingers.
                      BobH
                      #256779
                      KWIL
                        @kwil
                        BobH
                        The are standard sizes for rings, generally L – W, with suitable gauges to test fingers (and knuckels) for size.
                        #256783
                        AndyP
                          @andyp13730
                          Congratulations! Some random thoughts:-
                          A 2 morse taper covers UK ring sizes G to Q roughly so the most common ladies finger sizes.
                          A plastic cable tie makes a good finger gauge.
                          If you do make one a gentle taper is easier to work on – you only need one size after all.
                          Get a good finish on the taper because that will be the finish on the inside of the ring.
                          Leather or plastic hammers are great for stretching and won't mar the ring material.
                          The best thing about working with precious metals – if at first you don't succeed just melt it and start again!
                          Andy
                          #256793
                            A fiend of mine went on a 'make your own wedding ring' course. he was very pleased with the result.
                            Neil Lickfold
                              @neillickfold44316
                              If you have a lathe, just make a couple of form tools and turn up the ring to the profile and diameter that you want. I made my wife a Titanium wedding band for our 15th anniversary . I made a form tool for the inner shape and a form tool for the outer shape, parted it off. Then set it onto a mandrel and blended the side that was parted off. To get the size I just asked her to take a ring to the jeweller in town and got the sizing off them. They told her how many mm diameter it was.
                              OldMetaller
                                @oldmetaller
                                Gentlemen, thank you for the wealth of information and ideas you have presented, I knew you wouldn't let me down! Thanks BobH, I'm really pleased to hear that a 2MT mandrel will suffice as I have a couple of these in my 'lathe tooling' box, doing nothing.
                                Les Jones 1 and Jason B, thank you for the very detailed and specific info, I still don't pretend to understand the maths but at least I know what to do now!
                                AndyP, I'd better not get the cable ties out, last time I did that she phoned the police! wink
                                Once again, thank you all very much.
                                John.
                                #256887
                                Sam Longley 1
                                  @samlongley1
                                  Posted by Chris Evans 6 on 19/09/2016 09:42:32:
                                  How many times did you get engaged you cheep romeo?
                                  Hope you did not marry the one with the big fingers — never bodes well for the future frown
                                  #256888
                                  Sam Longley 1
                                    @samlongley1
                                    Posted by Neil Wyatt on 19/09/2016 12:51:57:
                                    Cannot have been that good — sounds as if he ended up married !!!!!!
                                    Edited By Sam Longley 1 on 20/09/2016 07:37:38
                                    #256890
                                    Chris Evans 6
                                      @chrisevans6
                                      Sam, I married a skinny one from Northern Ireland that I met in Spain. Still together after 44 years.
                                      The rings I made where a bit of a fun thing for a few girls that worked where I served my toolmaking apprenticeship and a few other friends. I did make my wife one but she lost it, hers turned out a bit wide to get down to the skinny size. 5/8" diameter from memory.
                                      #256895
                                      Gary Wooding
                                        @garywooding25363
                                        With over 55 years experience as a goldsmith I can assure you that there is no standard taper for a ring triblet. Choose anything that's handy and covers the size you need.
                                        In UK, ring sizes are denoted by the letters A (smallest) to Z (largest), with very nearly 1/64" (actually 0.992/64" between one size and the next. Conveniently, size C has an internal diameter of 0.5060", which is near enough 1/2", and size Z is 0.8625" which is near enough 55/64".
                                        You haven't said what materials you will use for the ring – what metal, what stone(s) etc. Your post suggests you will make the engagement ring.
                                        If this is your first ring I would strongly recommend practising before making the real one, especially if you intend setting stones.
                                        Please report back on your progress.
                                        Edited By Gary Wooding on 20/09/2016 08:14:52
                                        #256901
                                        davidk
                                          @davidk
                                          Surely if only making the one ring, you don't need a full length ring triblet, you could use a Stub Mandrel…
                                          #256903
                                          Gary Wooding
                                            @garywooding25363
                                            Posted by davidk on 20/09/2016 09:08:45:
                                            Absolutely! I'm sure Neil would agree.
                                            (I added the dimensions to indicate what sort of precision is required.)
                                            #256916
                                            Sam Longley 1
                                              @samlongley1
                                              Posted by Chris Evans 6 on 20/09/2016 07:43:17:
                                              Do they take long to make ??
                                              My wife reminded me this morning- as she went to golf- that I have forgotten out 47Th wedding anniversary ( for about the 45th year in a row) can one make one in the time it takes to play 18 holes , allowing for a few sliced shots & a cup of tea afterwards
                                              #256923
                                                I won't raise to the bait…
                                                #256948
                                                Sam Longley 1
                                                  @samlongley1
                                                  Posted by Neil Wyatt on 20/09/2016 10:57:06:
                                                  Clearly a seasoned forumite !!!!yes
                                                  #256960
                                                  Another JohnS
                                                    @anotherjohns
                                                    I made a ring mandrel for two engagement rings. Got the dimensions from the proposer, who is an engineer and who knew how to measure rings.
                                                    The mandrel consisted of 3 turned diameters; one for "hers", one for "his" and one to fit into a drill chuck. Rings made of wood – turned out beautifully, and they "worked" as the wedding was about a month ago.
                                                    #256962
                                                    Vic
                                                      @vic
                                                      Posted by AndyP on 19/09/2016 12:14
                                                      Andy
                                                      Is a brilliant idea. Why bother making something you're never likely use again when you probably already have something in the workshop.
