Making a polygon lathe cutting mechanism
Home Forums The Tea Room Making a polygon lathe cutting mechanism
  • #626238
    Steviegtr
      @steviegtr
      Not sure if anyone has seen this amazing guy making amazing things. This is a device for cutting most kinds of polygons on a rotating part in the lathe.
      Steve.
      Steviegtr
        @steviegtr
        Amazing work
        #626244
        peak4
          @peak4
          I spotted the same video, via Facebook, a day or two ago.
          I can remember seeing something very similar many years ago on TV; it might have been Tomorrows World.
          That one had the rotating cutting tool behind the headstock on a separate parallel spindle, and was shown cutting hex heads.
          Anyone else recall that?
          Bill
          #626251
          Rod Ashton
            @rodashton53132
            Wow! Makes you want to be an engineer??
            #627647
            Neil Lickfold
              @neillickfold44316
              I saw a picture of a system, where they have a spindle mounted on the cross slide, and has a cutter head on the headstock. Out the centre of the cutter is a universal drive or CV joint of sorts, a sliding coupling, and head stock has a 2 to one reduction on the spindle unit. If your lathe spindle is running at 700 rpm turning the cutter head, then the spindle on the cross slide holding the part to be polygon turned is running at 350 rpm. They had a range of cutters with 1,2,3 inserts. The accessory headstock came in different sizes etc. Looks like a great project to make as a kit or something. I do have a spare spindle from a cue making lathe. So it could potentially be used with a reduction box or belt drive. It will be down a bit of the list of things to make though.
