Every gib strip on all my machines are some form of steel, tapered rhombus shaped with screws at either end to adjust. They need to be perfectly flat, precise and smooth as silk no oil ways.
Pretty sure lathe cross slide is a decent casting, its broke a few times mid job. Didn't fancy the cost and no time to faff around making I usually weld up with inherent warping, file and diamond stone it back in.
The multi pinned rhombus style as used in Myfords dead easy, anything will do as long as two rubbing edges are parallel.
Its been a long time since done any pro scraping after a full precision regrind. Only time it was done was where punter requested as it aids oil flow but detrimental to wear ie less contact area. Funny almost every scrape job ever seen customer stating ive only took a couple of thou off turned in to 10 of thous to put right, its a fine art.
