Posted by Paul Davies on 18/12/2015 12:50:11:
Hi All.
I've acquired a 2MT ER25 collet chuck and collet set (the one ArcEuroTrade sell – the one with the M10 draw bar thread: 050-110-25530) and have been making an adapter to use it with my DW Mk1 mill, which has an M8 draw bar.
I purchased an M10x1.5 die and made my adapter – M10 male to M8 female.
The problem is that the adapter screws very sloppily into the collet holder. If I screw a normal M10 nut onto the adapter, there is no slop, so I guess the thread has been formed ok.
I'm wondering if the draw bar thread in these collet holders is an 'odd' M10 thread pitch. Does anyone know?
cheers
Paul
Paul,
I would suggest that the fit is fine as it is, provided you are using correct drawbar, i.e. metric M10 and not imperial. Do try out an M10 bolt as well as studding, as we have, and we confirm that there is no issue or cause for concern.
I would advise to leave the product alone without trying to modify it in any way. I would suggest that Tim Stevens comments are close to the truth and that if the fit is loose, it may be to avoid problems with distortion during hardening. But it isn't loose as to cause any issue. The drawbar – loose or tight simply holds the MT2 arbor in place to stop it from falling out. The MT2 in itself is a friction fit. If you still have doubts, return the set for a refund. Happy to take it back.
Ketan at ARC.
