Make your own ‘Air Rifle’
Home Forums Books Make your own ‘Air Rifle’
Viewing 25 posts - 26 through 50 (of 56 total)
  • #196856
    Ajohnw
      @ajohnw51620
      Captain raises some interesting points –
      Anyone who wants to shoot a rabbit and there are a fair few who do must seek the land owners permission. My problem is that I feel it's cruel given the power the guns have.
      Afraid it is possible to tamper with air rifles of both types that will pass tests but I would ask anyone who knows how to not pass on any details. In some areas of the country one method is pretty common. Why – because to kill a rabbit with any certainty it has to be used.
      Crime involving real fire arms isn't always reported nationally so I would take comments that it is falling with a pinch of salt. Armed robbery may be on the decrease but frankly I doubt if things like drive by shooting and related are.
        As admin I should say I'm OK with these subjects being discussed responsibly, but am sensitive if any dodgy practices appear to be condoned or explained, not least as my wife has narrowly avoided being 'plinked' during her work. That's why I edited your post John, although that trick was well-known when I was a teenager.
        It's interesting that,for whatever reasons, there seem to be more incidences of air reservoirs failing than model steam boilers, given that the majority of the latter are self-builds. I wonder how the numbers compare?
        Vic
          @vic
          Being able to adjust the power of PCP's is essential in some target sports to ensure you remain competitive without breaking the rules. Many of the top PCP's used in FT started out as 6ft lb ten metre guns that had their power levels tweaked, it's not difficult to do if you know what you're doing. You must have at least one Chrono though and better still checked with a second unit.
          #196882
          shaun hill
            @shaunhill88399
            Posted by Neil Wyatt on 15/07/2015 20:57:18:
            Neil, most of the failings of pcp cylinders are due most of the time to them being filled with oxygen or other industrial gases, The two that i heard about failing was basically due to user error, one way over pressurised the cylinder, and one had been bodging around,
            I have made my living for the past twenty five years manufacturing and repairing pcp rifles, and have seen more or less every pcp rifle made, some in my opinion are good others bad, the older pcps where always over engineered but the downside to that they where heavy, but some of the newer rifles leave a lot to be desired regarding cylinder thickness etc, most are made to the minimum spec required, unlike model steam boliers that are way over engineered in comparison.
            I have seen many rifles modified over the years that in my opinion are dangerous, usually done to try increasing the power over the uk limit, usually done by some have a go gunsmith who has no idea what they are doing, severely affecting the structural integrity of the rifle.
            The problem is, currently pcps dont need any sort of testing, as long as the cylinder holds under 500cc of air no test is required, so it opens the door for all sorts of modders and fred in the shed manufacturing, i personally think every pcp should be pressure tested and then checked every few years the same as diving cylinders and steam boilers, lets face it, there is in excess of 3000psi in these rifles and some are nearly 30 years old,
            I have not seen the book thats being disgust, so i cant comment on the rifles cylinder and pressure parts, but all i can say to anyone making one use proper spec tube and pressure test it,
            #196890
            Ady1
              @ady1
              I don't know where the Diana of my youth was made
              Diana fishing stuff was Japanese if memory serves(1980s). The guns were a side issue, they were just a cheap alternative to webley etc
              They may be German. The company has always been been very coy about its origins when advertising in the UK
              In the 1980s they had huge fishing catalogues, fishing porn for fishermen, the biggest in the business
              Edited By Ady1 on 16/07/2015 01:43:05
              #196903
              JohnF
                @johnf59703
                Many of the old Diana rifles probably up to about 1980/5 were manufactured by Millard Bros in Scotland they were branded Milbro Diana. We were selling these up to the time they ceased production I guess they were made under license form Dianawerk who also made the Original air rifles as well as their own brand Diana.
                #196905
                Eugene
                  @eugene
                  My late father used to say that any gardener pestered by rabbits was in need of a small boy with an air rifle ….. that's how I got my first one at age eleven. I was shown how to use it safely and responsibly.
                  In those days all you needed a ten bob Gun Licence which also covered shotguns, obtainable over the counter from your Post Office, I had one though I doubt many people bothered. I fail to be convinced that any licensing system will reduce the criminal or irresponsible use of guns, or ever has. I've gone through the ten bob job, the no licence at all job when that system was phased out and the new one brought in, and the modified legislation we now have; all in my experience and opinion equally futile. if a criminal wants a gun he'll get one and not bother with any legal process. The irresponsible and thoughtless will always be so; no bit of paper will alter that.
                  In response to John W1, a 12 ft/lb air rifle is perfectly adequate for rabbits and squirrels when used sensibly and accurately. The maximum practical range is about 35 yards, and only head shots should be taken. Using those two simple rules hundreds of thousands of small pests are humanely despatched every year.
                  I use a 12 ft / lb PCP .22 air rifle equipped with an excellent telescope sight for rabbits; I don't like the .22 rim fire on the stony ground we have, the potential for ricochets is too great, and a shotgun often smashes them up too badly for the table.
                  Eug
                  #196908
                  Vic
                    @vic
                    I still think the holy grail for air rifle design is a single stroke pneumatic. They were popular in 10m competition in the past but those were only 6 ft lb. No one seems to have been able to make a 12 ft lb version. Not only would they be safer – no storage of high pressure air required, but it would keep you fit as well! I guess we've all just become seduced by PCP's and we've become lazy. In the not too distant future perhaps folks will be too feeble to even cock the old break barrel ones more than half a dozen times! smiley
                    #196922
                    Ajohnw
                      @ajohnw51620
                      Posted by Eugene Molloy on 16/07/2015 10:03:57:
                      Eug
                      I shot several rabbits at well under 35yds so they must be made of much stronger stuff where I was shooting. Perhaps they were wearing crash helmets. Typical FAC air rifles give a good idea of what is really needed for pest control. That's what they are generally used for, cheaper than rim fire and safer too but perhaps not now that certain calibres are available that splinter on impact so that ricochet isn't so much of a potential problem.
                      My Diana would have dated from the 50's. Probably mid. I have no idea of power but I used to shoot precision 22 rim fire rifle at a works club uk style, out wards scoring targets, bull equivalent to hitting a pin head. I took it there a couple of times but there was a problem. If I hit the bull cleanly a flattened pellet would bounce back and hit me on the head. More recently I took a pcp to another club and used it at 25 yds. No where near as much power or accuracy as a result. In fact when lamping rabbits with it the pellet can actually be seen travelling for a long way towards the target. At more realistic distances it can be persuaded to shoot more or less pellet on pellet.
                      Vic
                        @vic
                        To prevent unnecessary suffering I think at least 25 ft lbs in .22 is more appropriate for pest control. Plenty of folks will "have a go" though with a standard Air rifle and once an injured animal wanders off is a case of "out of sight out of mind". If, and its a big "if" it was made illegal to shoot any animal or bird with less than say a weapon of 25 ft lbs then I'd be happy for Air Weapons to remain unlicensed but as things are I suspect an awful lot animals suffer and that's not including pets like cats and dogs that get shot by yobs from bedroom windows. I think the death of a young child shot by an air rifle has spurred the call for licensing in Scotland?
                        #196928
                        MSPF.
                          @mspf
                          OK, I've had enough. I'm off. Which will please those of you who are uncomfortable with my comments.
                          I have never come across a bigger bunch of soft jessies and establishment kiss a%$$3$ in my life.
                          Misinformation my eye. It's people like you that got us the limp wristed 12 ftp in the first place. Happy to see 25ftp used on bunny's and forget the license. HMM. how do you buy a 25ftp rifle without a license. That does not make sense, unless of course you know where you can buy one under the table, so to speak.
                          I thought this was a 'Model Engineering Forum', not a soap box for commercial and establishment yes men.
                          Regards all. Don't bother cheering I wont be listening
                          Bye bye girls.
                          #196932
                          Vic
                            @vic
                            It was forget the licence for 12 ft lbs like they're getting in Scotland but never mind. wink
                            #196934
                            Ajohnw
                              @ajohnw51620
                              This is way of target (pun) from the thread really but I agree with Vic except from USA practice and other info 18 is probably ok but problems get worse as power goes down.
                              Ballistics can roughly be scaled after a fashion so this page can be used to put power into perspective in terms of accuracy in particular
                              http://news.bbc.co.uk/sport1/hi/olympics/shooting/4725546.stm
                              Power 2,500ft lbs, bullet velocity – from memory they don't even go subsonic until something like 1,000 yds. The V bull isn't that small and the target itself is rather large both are easily visible at the distances mentioned and further. They use target sights not telescopic, 2 round holes. The ranges have flags dotted about on them so that people can adjust their sights to account for even a breeze let alone any wind. Both often vary along the path of the bullet.
                              Rabbits, air rifle at 35 yds no, maybe with something of an iffy kill aspect at 35ft or even less. The comment that is often made by people is that oh you need to hit a very particular rather small spot on their heads. Honest gun shops will sometimes mention that even pigeons can be a problem. They do get people come in who have pigeon problems. This area touches on why people with fire arms licenses who shoot animals always go for more power than they theoretically may need. All sorts of things come into it even shooting up hill or down hill and etc The other aspect is clean kills and risk. Risk limits power.
                              There are plenty of things that can be shot at local air rifle and even some gun clubs that allow both types of gun. Those can also often train people in the use of fire arms with club guns. Some air rifle field sports are very difficult to master. There is plenty to do without usually maiming animals.
                              winkI'm a frustrated gun slinger. My eye accommodation isn't really good enough for target sites any more and worse still while I was near a lighting strike that killed several people the end of my elbow was mildly damaged and I can no longer shoot prone. Sad as I was in the middle of taking up full bore which is very challenging. Far more so than others I have tried. The beebs description of full bore shooting isn't entirely accurate. The targets have trenches in front with people in them who mark the positions of shots with a rather long pole.
                              MalcB
                                @malcb52554
                                Posted by Vic on 16/07/2015 10:52:06:
                                Vic,
                                I had an Air Logic Genesis in .22 single stroke that was producing around 11.5 ft/lbs. trouble was it was like using a bull worker. Don't think he ever managed to get the .177 to do 12 ft/lbs.
                                The .22 was consistent thru' the chrono over about 8-10 shots then it used to " throw one" in at around 10 ft/lbs or so. Did a lot of experimenting with seals and pellet combinations, plus some mechanical changes ( including barrel ) but never managed to resolve before selling on.
                                Quite collectable now.
                                #196940
                                Bowber
                                  @bowber
                                  There's a lass down the road from us does full bore target shooting, her rifle was over £3K surprise
                                  Re licencing, is there plans for the UK? I have an old BSA Cadet Major and a newer co2 rifle.
                                  Steve
                                  #196943
                                  Vic
                                    @vic
                                    No plans for licensing here yet Steve as far as we know? wink Just those north of the border.
                                    #196944
                                    Vic
                                      @vic
                                      Posted by Malc Broadbent on 16/07/2015 17:20:31:
                                      Vic,
                                      Interesting Malc, shame it didn't work out.
                                      #196948
                                      Ajohnw
                                        @ajohnw51620
                                        Curiosity – what is a single stroke pneumatic?
                                        Eugene
                                          @eugene
                                          ""John W1 posted "Perhaps they were wearing crash helmets".
                                          Perhaps also apart from having no idea of the rifle's power and therefore shooting irresponsibly, frownyou didn't observe the six principles of marksmanship, didn't measure the distance, didn't know about correct shot placement and the angle at which your quarry presents itself, and didn't have confidence in your own abilities. If you hit a rabbit in the brain with an up to snuff air rifle under the 35 yards maximum, it's dead. The area in question is very roughly the size of a ten pence piece. If you can't manage that with good reliability, then you are wise to desist from shooting live quarry.
                                          As a twelve year old, with a Mk 1 BSA Meteor (well under 12 ft / lbs) I clean killed dozens of rabbits at modest (but known through constant practice) distances. The same applied to wood pigeon, and still does some sixty years later.
                                          I've had all sorts in my cabinet, from air rifles through .22 rim fire .222, .243 and once upon a time .308. In the right circumstances all are appropriate. You just need to know what you are doing.
                                          "Maybe with something of an iffy kill aspect from 35 feet or even less" … see the paragraph above. It is possible but futile to calibrate sights at ten yards, as it's pretty unlikely you'll get that close to a rabbit. The usual strategy is to sight in at twenty two yards which even schoolboys can judge as the length of a cricket pitch, and should be your ideal shooting range. Under that you hold low, and above it hold high, the degree depending on the characteristics of the particular rifle, and your knowledge of it.
                                          I have organised rabbit shoots with guests using FAC air rifles, who through improper shot placement wounded the beast when a correctly placed 12 ft/lb gun would have given a clean kill. On these occasions I always use a shotgun as a back up plus a well trained dog (as in all other live quarry hunts).
                                          It isn't the arrow that counts, it's the Indian.
                                          Eug
                                          #196967
                                          Eugene
                                            @eugene
                                            A single stroke pneumatic is similar in it's operation to a spring powered gun. However, instead of compressing a spring, it compresses a volume of air into a closed space. They are sometimes called "gas ram" guns; if you imagine something like the gas strut on a car boot lid you get the general idea.
                                            As a by the by, I never recommend using a spring powered gun, such as your Diana for hunting, they are far too finnicky as to how they are held; different hand placements give greatly different Mean Points of Impact and therefore an unacceptable degree of inaccuracy. This can be overcome with assiduous practice using what is called the "artillery hold" but in my experience few people have the required degree of application. A PCP gives another level of accuracy right out of the box.
                                            Eug
                                            #196978
                                            Anonymous
                                              Posted by Eugene Molloy on 16/07/2015 21:18:41:
                                              You are just describing a Gas Ram powered gun such as a Theoben type not a single stroke pneumatic.
                                              A pneumatic has a built in pump ,usually lever operated , which compresses air into a firing chamber then for all intents and purposes it fires just like a PCP. A single stroke is just that, usually seen on lower powered target rifles and would take a real force/mechanical genius to pressurise to the legal limit.with one stroke. I've still got a .20 Sheridan Blue Streak from the early 70s, a multipump that takes 6 pumps to get to the limit, after 4 it starts become a Bullworker.
                                              #196980
                                              Ady1
                                                @ady1
                                                after 4 pumps it starts to become a Bullworker.
                                                lol I had a sharp innova as a kid which made quite a crack when it went off but things got a bit sweaty if you were using it a lot
                                                #196989
                                                Eugene
                                                  @eugene
                                                  Mick,
                                                  You are quite right, I'd forgotten the true single stroke jobs.
                                                  Eug
                                                  #196994
                                                  Vic
                                                    @vic
                                                    This is a FWB 601 single stroke pneumatic. Lovely triggers on these rifles.
                                                    #196999
                                                    Oompa Lumpa
                                                      @oompalumpa34302
                                                      Rather late to the party here but I see we have some Air-Gun Royalty contributing. It's a small world is airgunning (and about to become much smaller in Scots-land – but lets not go there). I have observed arguments for and against 12ft lbs rage on many forums and my observation is we are stuck with it and that is pretty much the end of it.
                                                      Plenty of people have built airguns in their sheds and gone on to become quite famous in the world of airgunning: Bowkett, Whiscome and Ripley just to name a few. So why not build an airgun? Here is one that inspires me?
                                                      the link to further pics HERE
                                                      Personally I am building a double rifle in 22 Hornet for myself but this looks like a really nice effort. I think If I had built that I would have stopped there and gone on to other things I am also a great fan of Set Triggers – but each to their own eh? blush
                                                      Air rifles are great though, easy to biuld, modify and tune. Get yourself a little Chronograph and easy to keep it all below 12 ft. Lbs. I like the FWB 601 Vic, but I have an old and trusty FWB 300s which can outshoot me all day long, I love some of the vintage stuff. I also have a Sharp Innova somewhere with Target sights on it – can't imagine you would win anything though, apart from the "Big Biceps" competition.
                                                      Well, off back in to the Bat Cave for another day's toil. Though made that much more interesting by my restoration of a .500 Express Double rifle made by some outfit or other called Boss and Co. Looking down the bores is like looking down a pair of binoculars! But I am sure this will make it's way into a thread all of it's own.
                                                      graham.
                                                    Home Forums Books Topics
