Mains power supply for 12v dc motor
Home Forums Introduce Yourself – New members start here! Mains power supply for 12v dc motor
Viewing 3 posts - 26 through 28 (of 28 total)
  • #426823
      When making my original suggestion, I assumed [based on its declared purpose] that the motor would only be used intermittently. In which case, I was thinking of a battery somthing like this: **LINK**
      https://docs-emea.rs-online.com/webdocs/16c3/0900766b816c34e3.pdf
      … Which can be kept on permanent trickle charge.
      Is that unrealistic ?
      Frances IoM
        @francesiom58905
        SOD – yes the cost of a 120+VA transformer is way more than the cost of a single IC and a few components using a switched mode technique – these usually auto sense a 6V or 12V battery + depth of discharge – I suspect the 24V are similar. Gone are the days of a heavy transformer and the selenium rectifiers that indicated failure by odour.
        Re ATX PSU’s most do have a 5v minimum load requirement – the 80A server type are adjustable between 12.1 and typ 12.5V to allow for cable loss enroute to the compter board – on which is generally a smaller switch mode supply for the 3.3V – tho the one I illustrated will supply an 8A 3.3V standby supply for keeping some circuitry alive – it would be useful if two could be placed in serial to provide 24V but on all I’ve seen the bonding back to the case + earth makes this tricky (doable but needs a very awkward chassis isolation of one PSU)
        #426978
        Brian Fisher 1
          @brianfisher1
          Hi.
          Thanks for all your responses to date. I have not been ignoring you all but have been inwardly digesting all the comments. I am learning a lot from it all.
          One thought which has come to mind is that if a 20amp led power supply objected to the high inrush current of a motor would it improve things if a variable resistance was wired in series with the motor to give it a soft start. So long as I always remember to use max resistance at start-up.
          Or alternatively one of Geoff's suggested speed control devices.
          Cheers. Brian
