magnetic motor
magnetic motor
Home Forums Miscellaneous models magnetic motor
  • #441978
    Anthony Knights
      @anthonyknights16741
      I came across this **LINK**. while researching thermo electic devices. Comments welcome.
      Anthony Knights
        Whats the catch?
        #441982
          Brian G
            @briang
            In the earlier part of the video we can clearly see the operator adding energy to the system, just because I cannot see this being done in the latter part doesn't mean it isn't happening.
            Brian G
            #442031
            John Haine
              @johnhaine32865
              There's any number of these shown in YouTube etc – you don't have to work out how the trick is done, it is obviously a trick.
              #442033
              not done it yet
                @notdoneityet
                What is that solenoid on the side for? I expect there is an energy supply for that.
                #442049
                  Posted by not done it yet on 17/12/2019 09:36:34:
                  Is that a solenoid ? … it looks like a simple bearing.
                  Brian G
                    @briang
                    YouTube must have completely changed the economics of perpetual motion machines. Historically you either needed to scam a rich sponsor or a number of gullible investors. Now all you need to do is attract thousands of clicks and the ad revenue trickles in risk-free. Even the most skeptical viewer is contributing.
                    Brian G
                    #442053
                      Excellent analysis, Brian yes
                      Robert Atkinson 2
                        @robertatkinson2
                        The support / bearing on the side has at least got a spring in which transfers energy into the rotor when the pin is pulled. You can see effort being applied to pull it up at the end of the "run". It is large enough to have a AAA cell and solenoid hidden inside too if heeded. The small item under the wheel is also un-explained.
                        Robert G8RPI.
                        #442083
                          Posted by Robert Atkinson 2 on 17/12/2019 12:20:49:
                          Robert G8RPI.
                          All of which is consistent with the device being a development of Clifford’s “escapement”
                          [ which, incidentally, is not an escapement in the usual sense … but I didn’t write the patent; merely quoted it ]
                          Edited By Michael Gilligan on 17/12/2019 14:48:43
                          #442145
                          Howard Lewis
                            @howardlewis46836
                            Claims of having invented Perpetual Motion are being made perpetually. A few seconds thought will bring the conclusion that they are either mistaken or dishonest.
                            Some one has to pay for the "free" lunch|!
                            Hopefully, some of the schemes will provide, at least, a wry smile.
                            #442148
                            Brian Oldford
                              @brianoldford70365
                              Do I smell Snake Oil?
                              #442156
                                With no intention of introducing the Brexit ‘backstop’ into this discussion …
                                lt is worth noting that the claim in this instance is for “Spinning Indefinitely” not ”Spinning Perpetually”.
                                … Not quite the same thing.
                                devil MichaelG.
                              Home Forums Miscellaneous models Topics
