Magnetic chuck/plate construction
Home Forums Beginners questions Magnetic chuck/plate construction
  • #52544
    Graham Horne
      @grahamhorne65034
      Gentlemen, I wish to build a magnetic chuck and because I am not as
      computer adept as you lot, do not surf well for info. Can anyone suggest
      sources they have seen which detail things like.. coil winding, horizontal
      or vertical placement, parallel alignment, materials, voltages, size selection.
      Acknowledgement will be given if an article eventuates. Thanks…GH
      Graham Horne
        @grahamhorne65034
        #52548
        Peter G. Shaw
          @peterg-shaw75338
          Hi Graham,
          Dave Lammas discusses mag.chucks in a series in ME starting 03 Feb 89 ending 02 Jun 89.
          Also, Michael Jacot in ME 01 Aug 97 discusses a mag.chuck using a ceramic magnet from a bus gear box. At the time, I did wonder if it might be possible to use a ring magnet from a loudspeaker.
          Peter G. Shaw
          #52554
          Ian S C
            @iansc
            Micro wave ovens also supply 2 magnets similar to speaker magnets- about 2″ + – 1/2″ or so, I’v used both. Ian S C
