For what it's worth, which may not be much, the data collected from my experimental pendulum didn't contain a trend that might have been caused by its' bob becoming magnetised.
The pendulum was a short length of carbon-fibre rod with a mild-steel bob. The bob was energised unconventionally at the far end of the swing by an electromagnet from a dismantled relay, the idea being that the bob would be gently attracted towards a timed electromagnet in hope of reducing impulse shock and not 'dominating the clock'.
I assumed the relay core was built to minimise residual magnetism, but recognised the bob itself might become magnetised.
The pendulum was energised by an Arduino connected to various sensors and arranged to measure short times accurately:
- Second pulses from a GPS unit were used to calibrate the Arduino's crystal oscillator: the Arduino measured how long it thought a GPS pulse was, and the difference revealed the actual frequency of the computer's crystal, including shifts due to temperature, so the Arduino's report of pendulum swing time were dynamically tweaked accurate to within about 10 microseconds.
- Once every 'n' swings the Arduino also measured Temperature, Barometric, and Humidity
- The need for an impulse was detected by measuring the time taken for the pendulum to pass between two adjacent infrared sensors. Pass time is proportional to amplitude, and – to minimise shock – an impulse was only generated when the amplitude fell below a certain value.
- All this data was transmitted after each swing to a RaspberryPi. The RaspberryPi was set up mainly to log the data over long periods (years if necessary), but it was also programmed to time-stamp log entries with accurate internet time, which is always correct to within about 15mS. Thus the log contained time stamps capable of detecting microsecond variations per swing and time-stamps capable of measuring changes of rate over long periods.
The log was transferred to a PC for analysis and graphing. The data showed the pendulum wasn't a good performer, mainly because the Q is low and – worse – my suspension allowed the bob to swing in an ellipse, which it often did! The pendulum was also markedly sensitive to vibration, including cars passing 20 metres away.
The analysis included a search for correlations, which showed my pendulum wasn't effected by temperature, was slightly effected by changing air-pressure, and was distinctly sensitive to humidity. Although carbon-fibre is stable, it seems the matrix that forms it into a rod isn't!
Anyway, my data shows no sign of the bob being effected by being progressively magnetised. The results don't prove residual magnetism is never a problem! My small bob was designed to be impulsed unconventionally by tiny intermittent pulses; maybe magnetism would show up on a bigger clock pulsed conventionally.
Another thought, my clock was tested on a table where the pendulum was aligned North-South with the earth's magnetic field. Would residual magnetism make a difference if the bob were swinging East-West?
I keep meaning to have another go, applying 'lessons learnt'. One way and another I've never got round to it.
