Mark they are absolutely fine for reading on the screen it is just that the snipping tool is a low res image, just like scanning a document at 300dpi rather than 1200dpi so quality is not great.
Compare a quick 2.5Mb photo of the screen with the 100Kb images I posted above
![20191210_065944[1].jpg 20191210_065944[1].jpg](data:image/svg+xml;base64,PHN2ZyB3aWR0aD0iMSIgaGVpZ2h0PSIxIiB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciPjwvc3ZnPg==)
Facility was removed when the viewer was updated as it was not available on the newer version at the time, the readers of Hello and OK don't seem to have the need to print their mags!
You can also blow them up larger on the screen if normal A4 is a bit small.
As Paul says said paid subs are best viewed via pocketmags which is a better viewer and still has the ability to print 2 pages at a time but won't go back into the archive.
Edited By JasonB on 10/12/2019 07:03:07
