Posted by Raphael Golez on 25/05/2020 20:53:54:
Bill, great close up macro. Is that corrosion in your taps or just work debris? Are you still putting extension tubes on your 150mm Macro? Very nice! Are you using off-camera flash or this is all natural light? Keep posting your pics.
Edited By Raphael Golez on 25/05/2020 21:01:50
Cheer Raphael, I don't think I've ever used the 1mm one, it just came as part of a very cheap set 35+ years ago, and has probably got a touch of surface rust. Clearly it's quite poor quality, but the dies that came with it have been used for some 1.2mm & 2mm screws I've made to repair a spotting scope.
The 10BA one looks like it's been badly stored in the past, as the shank is unreadable, but that was clearly used before I bought the set second hand as the business end was still full of tapping fluid.
The camera is micro 4/3 but the 150mm Sigma macro lens is normal 4/3s so needs an adaptor to work OK with the newer camera.
The 4/3s standard only allows the use of one accessory at a time, so you can use a teleconverter or an extension tube, but not both at the same time, which is a pain.
It's possible to fiddle things a bit more with micro 4/3, so these last two photos were taken with a combination.
First the camera body, then 10mm + 16mm extension tubes, then the 4/3s to micro 4/3s converter, followed by a 4/3s 25mm extension tube, and lastly the 150mm Sigma.
The lens itself goes up to 1:1 and then a further 51mm of extension tubes, so not sure what final magnification it ends up.
I did try the same setup using the 4/3s 50mm macro, but the focus point was only about 10mm in front of the lens; the 150mm Sigma gives a better working distance.
One clever facility of this Olympus body, is that it allows "in camera" stacking of up to 15 images, each with a slightly different focus point. (It also allows auto stacking of 99 shots, but that one needs to be stacked in an external program.
Unfortunately, with the Sigma lens being non-Olympus, this facility is disabled, hence using F11 for the last two shots.
I do have a later Micro 4/3s Olympus 60mm macro which I used with the pair of extensions in the previous photos.
That allows stacking fine.
All photos were in natural light in the conservatory.
It was more of a problem with the recently uploaded album of Milling Cutter Chucks, I mentioned in another thread I originated a couple of days ago. The lighting angles caused too many highlights. Drawing the blinds didn't help as there was too much light coming through the plastic roof. Arguably I might have been better with a ring flash, or a home made LED ring light I made years ago, before these new halo lights arrived on the scene.
I don't claim to be experienced in macro photography at all, though i do take shots every now and then; it was your initial post that prompted me to have a play, so thanks for the prod with a sharp stick.
Bill
