A couple of years ago (22nd May 2020), soon after Raphael’s thread became piggybacked with 3D images, I experimented with views from my skeleton clock CAD files.
For reference, look towards the end of … **LINK**
I noted then that a five-degree rotation of the CAD image seemed to work.
Before my enthusiasm faded, I messed about with a pair of plastic-coated paperclips that I could rotate five degrees. Photographed through a 100mm Macro on my Canon 300D here is the result for parallel and crossed viewing.
It’s quite clear that I could also have skewed the clips themselves to increase the 3D effect. Instead, I gave preference to depth of field.
Clearly, although only one camera is necessary, this (table-top) method is only suitable for static objects. I certainly look forward to your two-camera results Nick. My thoughts about synchronised shutters were more to do with if and when you turn your attention to animated objects.
Cheers,
Sam
