Hi, been awhile since I last made a stereoscopic photo, so I though I'd give it ago using my Canon IXUS 170 compact camera. It soon became aware that the subject that I've photographed wasn't easy to achieve, as lighting was a problem to get right, it was either too bright and washed most of the detail away, or I got good detail but a lot of darkness making other parts hard to see. My solution was to cobble together an angle pose lamp with a daylight bulb in it and a lamp dimmer, but it still took a lot of trials to get what I considered a satisfactory result, the bronze look is the result of the dimmed light bulb. the 3D effect is a little shallow but the main subject does stand out from the background and does work well using a stereoscope.
Photo numbered 1 is for parallel view and 2 is for cross view.
The bearing is from the HSA (head stick assembly) of an old hard drive, not that I was measuring it particularly, it was just that it was small and easy to mount into position and was to hand.
Regards Nick.
P.S. if anyone wants the photos without the grey bar in the middle, just say and I'll do them.
Edited By Nicholas Farr on 30/12/2021 23:10:09
