Hi, so, here's a brief description of my technique, first the camera was mounted onto my X/Y camera mount and that was then mounted onto my K & F Concept TM2515T1 in the manner shown below.
This was then set up in front of the fridge magnet in the next photo, with the closest part of the fridge magnet, directly over the centre of the tripod's rotating head where the horizontal bar passes through.
This was then adjusted to be square in all plains with the fridge magnet and the distance from the fridge magnet was adjusted to get it framed and at the same time the fridge magnet was adjusted up/down and side to side to get it central in the frame, which took a fair bit of tweaking. I then did what I though would be the angles that my eyes would be at while looking at the fridge magnet from the same distance as the camera was set at. I then used a simple protractor to swing the camera to the right, by lining up by eye, the horizontal bar.
The first photo was then taken with both my macro lens lights on the dim setting and the shutter was set to delay, so that any slight movement by pressing the shutter release didn't cause any camera shake. The camera was then swung to the left hand side and the above was repeated. The images were then downloaded and processed into the stereo pairs.
Regards Nick.
