Raphael, those images are superb.
I'll mention a few points about the Novoflex bellows shortly.
This morning, I explored the CAD file-viewer’s rotation adjuster using the full clock file. It was pleasing to discover that not only could the image be rotated, but it could be set incrementally.
It took a couple of tests to determine what appeared to be the better ‘Z’- axis ‘increment’.
1° was insufficient while 10° was excessive, so I used 5°.
Having forgotten to set what is called ‘Environment Map’, the image doesn’t look as shiny as before. However, it instantly jumped to 3D when I went cross-eyed. There are still a few twitchy artefacts from the outlines, but overall it was a pleasing result.
For those that need to switch left for right, go to …
