I've hand-sawn grade 5 and I'd rather not do that again. It can be hammer formed cold (0.7mm sheet), but it takes some effort to get it to take a permanent set and the stuff hits you back. Grade 1 is far more forgiving.
Hot forging is much easier. Some US smiths have rather snazzy forging tongs made of Ti, the lower heat conduction is supposed to be a boon (although in reality I suspect it's for bragging rights).
A laser welder will join Ti happily (under argon), but a) it's only good for thin pieces, say up to 2mm, and b) the weld can still end up brittle – I need to see if I can anneal it successfully. Can't do vacuum annealing, but I can use tool wrap and some charcoal to scavenge O2.
I also have a few small blocks of aero origin, no idea what alloy though.
