Thanks for replies – I think my questions have been answered. Neil Lickfold's detailed report on speeds, feed &c is especially useful.
It seems that I shall have to don my bio-hazard gear and crawl under the lathe to inspect the suds sump. I rarely use flood coolant (messy) but it sounds like I should for this task.
Posted by SillyOldDuffer on 25/04/2021 10:17:28:
Doesn't seem likely Titanium soaked in water coolant would catch fire, but a bucket of sand in the workshop would be sensible, just in case.
What fun. Please report what happens Robin. Although my money is on success, failures are educational too!
I don't intend to invest in a class D extinguisher, but might run to a tub of finely-powdered salt which might be better than sand in the event of an emergency. Apparently that's what's in the extinguishers – the salt melts and make a crust over the blazing inferno. And presumably sucks out some energy in the latent heat of fusion.
Something in the article Dave linked to confused me at first:
"Use of relatively high speeds of travel. Temperature is less influenced by speed of travel than by cutting speed. Travel speeds should therefore be as high as compatible with efficient working."
I initially read that as the statement of a general principle, which I couldn't understand. On reflection I think it's to do with the low thermal conductivity of titanium. Presumably the high rate of travel just distributes the heat over the work more rapidly than thermal diffusion, and therefore results in lower local temperatures. Is that right?
Mick – I had thought about carbide drills but was put off by the cost. Nearly £50 for a 5mm drill from RS! But Ive found that Zoro list a 5mm Dormer carbide stub drill, which will do me fine, for £5.99. I don't need to drill deeper than 8mm so I'll probably go that way.
Robin.
Edited By Robin Graham on 27/04/2021 00:25:39
Edited By Robin Graham on 27/04/2021 00:26:11
