Perhaps unwisely, I agreed to make a kitchen utensil for my sister in law. It's a potato masher – basically a disc with a pattern of slots, mounted on the end of a shaft with a handle on the other end. Yes, I know you can buy such things, but I'm tasked with copying the design of a much-loved tool which has finally expired, and which is no longer availed commercially
Anyway, I thought that stainless steel was the right material to use, so a rummage in the scrap bin brought a suitable sized piece of 2mm plate to the surface. Now, I have little experience of working with stainless, but my attempts to machine this plate have been less than satisfactory. After just 1 slot with a new 5 mm carbide slot drill running at 500rpm the cutter has lost its edge, and the slot is very ragged. I guess the problem is the material work hardening. Am I using an unsuitable grade of material, or is my technique wrong? Is there a free machining version of stainless sheet?
