A long time back I machined the crankshaft for a 360 cc flat six.
In order to minimise deflection and chatter while machining the various journals I filled the gaps between the webs of previously machined journals with polyester resin by masking off most of the gap and leaving just a small hole through which the resin is poured. When finished drop the crank into a tank of Acetone to dissolve the resin.
