Machining EN36
Machining EN36
Home Forums Materials Machining EN36
  • #110246
    Old School
      @oldschool
      Any tips on machining this steel I intend to make a pair of bevel gears, and also the case hardening and tempering.
      The final application is a tether car gear gearbox so they need to be tough should rev to 20,000rpm
      Thanks
      Oliver
      Old School
        @oldschool
        Steel EN 36
        #110249
        John Stevenson 1
          @johnstevenson1
          It machines really nice, just need sharp tooling and don't get it hot or rubbing
          #110321
          colin hawes
            @colinhawes85982
            I have always machined EN36 with high speed steel tools with no problems at all. Colin
            #110322
            colin hawes
              @colinhawes85982
              I used to have access to cyanide case hardening which was ideal for such an application ,leaving a clean finish although I don't know if you can still get this done. I don't think tempering is needed or desirable for high speeds. a 10 thou. case would be OK. Colin
              Edited By colin hawes on 28/01/2013 15:28:42
              #110390
              colin hawes
                @colinhawes85982
                Following my last post ,on second thoughts reduce that case thickness to 5 thou .for that size of gear. Colin
                #110392
                John Stevenson 1
                  @johnstevenson1
                  I agree with Colin, cyanide harening or what is now used instead of cyanide commercially will work fine.
                  There is no need to temper EN36 as it's not a thru hardening steel, the core stays tough as opposed to soft.
                  EN 32,33 and 34 are thru hardening steels which need to be tempered or they can become too brittle.
                  The untimate without resorting to specials is EN39B which is like EN36 on steroids, just stronger and again not thru hardening.
                  We make crankpins for racing engines out of this if they are one piece as it combines hardness with toughness.
                  #110408
                  Old School
                    @oldschool
                    John, Colin
                    Thanks for the replies very helpfull, I was planning to use Casenit to case harden in the lab muffle furnace you can control the temperatures very accuratley in it.
                    Olly
                  Home Forums Materials Topics
