Machining cams on the mill
Home Forums General Questions Machining cams on the mill
  • #755723
    Dougie Swan
      @dougieswan43463
      Hi
      Some time ago I watched a video about making cams on a mill but can’t remember where or find it again
      Can anyone point me in the right direction
      Thanks
      Dougie
        What method were they showing? Boring head, Cam-Calc (where the head is raised and lowered) CNC or something else?
        #755726
        Dougie Swan
          @dougieswan43463
          Hi Jason
          One method showed the mill running in reverse and the other forward
          Dougie
          #755727
          bernard towers
            @bernardtowers37738
            Model engine news an article by graham meek for one but there are more out there. HMEM. Motor boys etc.
            #755729
            Dougie Swan
              @dougieswan43463
              With a boring head
              #755731
                Search “Hoglet cams” on Youtube there are several there using that method. Same way I did mine.
                #755733
                noel shelley
                  @noelshelley55608
                  A number of years ago in ME there was a very long series on vehicles and engines, I had worked on engines for decades but had never realised how complex the shape of a cam was. Noel.
                  #756031
                  Howard Lewis
                    @howardlewis46836
                    Cam forms are quite complex, on high speed engines; to prevent valve surge, and to keep the forces between follower and cam to acceptable limits.
                    Ideally the valve opens to full lift, almost instantly, and closes in like manner, but the forces involved in even approaching this can be huge.
                    The faster that you try to open (or close) the valve, the greater the forces to accelerate / decelerate it, and then lubrication breaks down, and wear sets in, if the rest of the valve train doesn’t suffer damage from the forces involved (bent /broken push rods, rocker pedestals, and rocker levers, for instance).
                    Overhead cams, acting directly on a bucket type valve cap have much lower inertia than push rods and rocker levers, hence their use for high speed, high specific output engines.
                    But for most of the small four stroke engines that are modelled, high speeds will not be required, fortunately, nor high specific outputs. But “round the pole” racing cars, or hydroplanes can bring problems more akin to full scale.
