Hi There
Rough sketch but the principle should be clear.
The Z height is stepped at say 0.5mm the Y is where the 0.5 intersects with the path of
the 8mm ball nose.
If you move the cutter to these co-ordinates and take a cut, you will generate the cam.
You can start at the top or bottom of the cam, does not matter which.
The path is for the centre of the ball, if working manually the Z will be 4mm lower.
If using CNC, allow the 4mm in length compensation.
![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Edited By David Clark 1 on 30/06/2011 19:33:06
Edited By David Clark 1 on 30/06/2011 22:16:40
