Anthony
I presume you don’t have a full form 1.5 mm pitch threading tool as this makes the job very easy as you can work direct to standard dimensions. The big problem when using the usual home ground tool is getting the actual in-feed depth just so to cope with the inevitable errors in tip truncation and lathe characteristic induced differences between what the dial says you have fed and what actually gets cut.
Basically you need a way to calibrate these errors out so the actual thread flanks are in the right places.
I’d tackle it by cutting a nice 1.5 mm pitch test piece to fit a decently long hole cleanly tapped with a nice sharp tap. M 10 x 1.5 about 15 to 20 mm deep, including lead in and start bore, should do nicely. Aim for at least 8 quality, full depth threads.
Best way to cut the test piece is with the “zero-2-zero” angular in-feed method as it allows you to directly calibrate the offsets needed to take out any error. To use this method the top-slide is rotated to a little less than the thread flank angle, my top-slide is pretty much permanently set at 25° to do both 55° and 60° threads but arguably 28° is better for 60° ones. Not that I’ve noticed any difference. After the work-piece OD has been turned to size the tool tip is bought up to touch the work and both thread dials set to zero. Use the cross slide to bring the tip just clear of the work and use the saddle to take the tool past the end of the work. Now feed the cross slide forwards from zero by the depth of the thread you intend to cut and re-set the cross slide dial to zero. Use the top slide to withdraw the tool just clear of the work then thread using the top slide to set the successive cuts and the cross slide to withdraw the tool to return to the start after each cut. Obviously the cross slide is moved back to where the dial reads zero for each cutting pass. When both dials read zero and all spring cuts have been taken the thread cut is what you set up.
Ideally it fits the test piece. In practice it is almost invariably needs an extra cut or two to get a nice fit. Because your nominal depth setting is on the two zero’s its easy to add known amounts of extra cut until the fit is right. My practice is to use the cross slide, making the extra cuts by the straight in method, leaving the top slide set on zero. When I get the right fit simply adding the cross slide reading to the original “book” depth gives the correct cut to set-up next time. Alternatively the top slide can be used and a note made as to the new “beyond zero” finishing point, don’t attempt to re calculate things so the top slide finish point is shifted back to zero.
Slide locks and good feed stops make life easier but many small lathe feed stops aren’t repeatable enough. The SouthBend one being a case in point, 2 or 3 thou variation being common. As ever with the angular in feed method extra thought and care is needed to create clean shoulders and the end of the thread. Best to cut a suitable groove first.
