In a vice, skim one face flat.
Set that face against the fixed jaw and skim 2nd face, holding a short stub of metal against the rough front and the movable jaw.
Rotate through 180 degrees with second to the bottom, skim 3rd face face to size
lay 1st face to bottom, clamp in vice across faces 2 & 3 skim 4th face.
You now have a choice, clamp in vice across 2 & 3 faces mill end face (5th) rotate around and mill 6th face OR clamp across faces 2 &3 with a good face set vertical with a DTI and then mill top face, rotate 180 degrees and finish last face. Checl for square and if not already to exact size, finish to size.
Again, easier to do than explain.
