Posted by Ronald Morrison on 01/06/2020 10:42:40:
i put off buying a bandsaw for years, using the hacksaw for all my small cutting and oxy-acetalene or plasma for the bigger cuts. What a mistake! Now that I have a bandsaw I will carry parts 100 meters to the bandsaw instead of picking up the hacksaw that is 1 meter away. The accuracy of the cuts is better than I ever managed with the hacksaw and I can clamp the stock in, start the bandsaw and walk away to do other things, knowing that the bandsaw will just shut itself off when the cut is done.
+1 in favour of the bandsaw! Not sexy but my goodness they save time and effort. Doubly appreciated because hand-sawing must be the most boring, tiring and least rewarding of all workshop activities.
In order:
- Hand tools, Taps & Dies, Digital Caliper, bench, vice
- Pillar drill & Grinder
- Mini-lathe
- DTI, Stand and Micrometer
- Bandsaw
- Insulating Bricks, Seivert Torch
- Engine Crane
- Milling Machine with Drill and ER32
- Parallels, Boring Head, Rotary Table, improved vice
- X,Y DRO for mill
- Angle gauges, Wixey and Angle plate
- Replace mini-lathe with big lathe
- Ball cutter, knurling tool, rear toolpost, Reamers, centre set & other accessories to fit big lathe
- Planisher
- Improved lighting
- Air Compressor
Dubious purchases: 3-in-1, Height Gauge, Scribe Block, milling vice for Mini-lathe, Flood Coolant system, Clamp Set, Press, Engineering Blue
Made Redundant by Milling Machine: Pillar Drill (mostly), Tap Stand.
Completely Daft: cross-vice.
