machine lighting
machine lighting
Home Forums Hints And Tips for model engineers machine lighting
Viewing 14 posts - 26 through 39 (of 39 total)
  • #225367
    Ajohnw
      @ajohnw51620
      Out of interest I discussed lighting with a swedish lighting engineer who happened to be around when the topic cropped up. Seems that only warm white led lighting is available there. I wonder why, no point in repeating myself. That's what IKEA sell too. I reckon that they are a touch cooler than the usual tungsten lights. Most fluorescent tubes are warm white too. I've fitted some that should be suitable for colour work according to some standards but I'm not sure I like them so I guess the tubes I bought will last for a very long time. Mind you they should stop me from suffering from SAD. Not that I ever have.
      The led lights I linked to use 15 or so led chips over an area so none of the point source problems.
      Ajohnw
        @ajohnw51620
        The person that started Screwfix up sold it to the B&Q stable. He kept prices down by being careful about what he stocked. After he sold it he started up ToolStation. Same basic idea. Looks like the Wicks stable has bought that now.
        I had heard from a friend who it seems has talked to him that he is going start up another.
        Frances IoM
          @francesiom58905
          Screwfix no longer lives up to its name – many of the useful machine screw lines were dropped and quality of many products seems very variable – not so sure re Toolstation – Wickes used to have some good own-name products but these appear to have been phased out – locally here in SE Screwfix,B+Q, Wickes and Toolstation are within a 100 yards of each other so must be plenty of room for yet another competitor – what is missing is an outlet for good quality handtools etc
          #225383
          Ajohnw
            @ajohnw51620
            Toolstation is in Wicks round here. Not sure how normal that is. Since I selected the local store it shows me how many of the items I look at are in stock in that store. They seem to be working on the basis of keeping a few of everything were as the local Screwfix has lots of people in it and is pretty big which must up the costs.
            I generally buy power tools via brand name now and use mail order. I did buy some B&Q power pro stuff but that doesn't seem to be an option any more. It was fairly decent stuff hence giving trade users a more restricted guarantee.
            Edited By Ajohnw on 14/02/2016 20:05:25
            #271728
            David Jenner
              @davidjenner61726
              I've used several of the IKEA angle-poise type lights in my workshop in the past, works a treat.
              I've just bought one of the freestanding bendy led lights, planning to add a bracket instead of the freestanding heavy base.
              Should be just right for the mini lathe!
              David J
              #273123
              Nick Hulme
                @nickhulme30114
                I'm using a lot of GU-10 light fittings with 4W to 6W "Daylight White" LED spotlight bulbs and find the colour temperature is excellent for fine work, by using several lights in different positions to illuminate a workspace it's possible to eliminate problems with the shadows of hands, tools or work on the workspace,
                – Nick
                #273124
                John Haine
                  @johnhaine32865
                  Posted by Ajohnw on 14/02/2016 10:58:49:
                  …………….Out of curiosity I looked at the light out of the led lights with a spectroscope. No spikes, unlike the spirals. Must admit that surprised me and I suspect it's down to the white envelope that forms the bulb shape and contains the leds.
                  The white envelope couldn't of itself add any extra spectral lines. LEDs normally emit quite a tightly defined spectrum. I believe that some "white" ones use 3 separate LED types to appear white through mixing appropriate primary colours, but other white types actually emit ultraviolet and use fluorescent-type phosphors to convert to white.
                  #273132
                  Hacksaw
                    @hacksaw
                    I've seen on here a reference to strobe effect on machine lighting and a lathe could appear to be stationary when its actually running ? Well , on Sunday i bought some clear LED bulbs ,with fake filaments in screwfix ,for the living room …..and when the dog wags his tail , it looks like he has a dozen tails !!!! laugh  Hertz  indoors noticed it first…crying
                    Edited By Hacksaw on 21/12/2016 15:17:00
                    #273136
                      Posted by Hacksaw on 21/12/2016 15:14:47:
                      I like that yes
                      #273142
                      Muzzer
                        @muzzer
                        It's quite likely that many LEDs will flicker. The exception would be those that are powered by a DC supply rather like a laptop PSU. Many of the standalone drivers are "constant current" devices that use PWM to regulate the current. Most external car lights (including some headlights) are LED and you get a fairly obvious strobing effect from them.
                        Mains bulbs don't have the space or the need to accommodate the components required to provide a flicker-free output. I noticed that the trendy "LED filament" bulbs are little more than a series capacitor (to limit current) and a bridge rectifier. They will certainly flicker at 100Hz.
                        If you do the sums, you will find that a capacitor that will store enough energy at around the typical bulb voltage will end up about the same size as the bulb itself – and cost more. The PSUs mentioned in the first paragraph store their energy at ~340Vdc and the required cap size is significantly smaller.
                        I'm not convinced there is any significant risk unless you are stone deaf, mind.
                        Murray
                        #273159
                        Vic
                          @vic
                          The halogen lamp on my VMC is absolutely fine in spite of the light being quite yellow. The cool white LED lamp I bought for my Lathe however is pants. I won't be buying any more LED lighting until the light quality improves.
                          #273169
                            Posted by Vic on 21/12/2016 18:41:29:
                            Do yourself a favour, Vic … try some 'Warm White' LEDs before giving-up on them.
                            The CRI [colour rendering index] is typically much better.
                            Nick Hulme
                              @nickhulme30114
                              I've been testing LED lighting since they first popped up as replacements for conventional mains bulbs.
                              Cool White tends toward the blue end of the spectrum and is rubbish for detail vision.
                              Warm White is better than Cool White but tends to the orange/red end of the spectrum and still isn't brilliant (no pun intended) for fine detail vision.
                              For a reason I cannot fathom what no shops tend to stock are "Daylight White, which are a well balanced bright white light very well suited to fine detail vision,
                              – Nick
                              #296985
                              Hacksaw
                                @hacksaw
                                Anyone got a guitar handy ?
                                I was just being Jimi Hendrix at Monterey blush , playing Like a Rolling Stone….when.
                                Check out the open A string struck under LED filament 240v lighting !!!
                                Hertz (i guess )is a similar frequency…. laugh I thought my eyes had gone wonky for a minute! blush
