Hi Andrew
I meant to say this as posted at the other place
"Now for the exciting part; Hidden at the bottom of the Gaussian graph there is a tiny numeric value, It followed my indicator movement when I moved the slide. very roughly a value of 1 to 4 on the graph value to 1 to 4 ticks on the 0.01mm indicator. I assume this correlation may not have been planned however with the particular camera I used it was very convenient.
I ran the test several times and it was repeatable.
0.01mm is equal to .00039" (about 4 tenths)
A very good result from a crude setup."
There is an error in the scaled value that needs to be explained. The dial indicator readings and the values on the screen correlated and were repeatable.
Hi Clive
Yes there is more work to do on this project, For a start I want to use the sensor to work with backlit .008" stretched wire without a laser and no lens, just the shadowed area of the wire on the sensor. I am working on something I intend to show at the MSMEE Exhibition in Melbourne in 5 weeks.
You are right using a modern PC enables number crunching speed unobtainable not that many years ago, T 640×480 webcam came from the junk bin. Now 1080p camera modules are dirt cheap some under 20 dollars
The colour image is converted to grey-scale by the software.
I will keep working on this project.
Edited By John McNamara on 24/08/2019 12:59:40
Edited By John McNamara on 24/08/2019 13:06:43
