I powered up my KX1 setup yesterday and XP bluescreened. Properly.
Then I managed to ensure that the O/S was unrepairable.
The system was built on a Dell desktop using XP Service Pack 3. Mach 3 (USB config) was the original "locked down" version supplied by ArcEurotrade. It has run for quite a few years now without a hitch and has served me well.
I've put the hard drive in another XP machine of the identical specification as drive D: If I run the version of Mach3 using the command line prompt that is on the D: drive – all works fine.
Question – what directories do I need to copy across from the D drive so Mach 3 will run exactly like it has always done but from the C: drive?
Steve
Edited By Steve Withnell on 02/05/2023 13:50:56
