yep that version seems to me to be full of inconsistencies, if I install that on my Mill it becomes very unstable, with the older version I can run 3 mpm cutting figure of eights, and a full cup of coffee doesn't spill, the movement is so smooth, however install the later version and it becomes a different animal, I've spent ages retuning the Servos to no avail, I gave up in the end a reinstalled the earlier version.
My PC was found in a skip, is 1Gig CPU with 3Gig ram, a very basic video card a 10 gig HD, running a standard install of XP pro and two printer ports, however my VFD is LG, its in the same box as the controllers and PC, I have Planet Rock playing on the radio which is sat on top of said box, whilst the miller is taking a 4mm depth of cut with 8mm stepover at 900mmpm in 7075 ali, as of today according to the run time clock, I have run well over 9,000 hrs with this setup, I have no line filters and no problems!! ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Shaun
Edited to add, I also have a cheapo Huanyang inverter on my lathe, which is next to the miller this doesn't effect the CNC mill either, although I rarely run them both at the same time.
Edited By Involute Curve on 16/06/2015 13:25:46
