Mach 3 doesnt see UC100 contoller
  • #15172
    Peter Bell
      @peterbell11509
      Peter Bell
        @peterbell11509
        Installed Mach 3 on my windows 7 computer making sure I left the parallel port un ticked and followed the reboot instructions, also intstaled the UC100 driver. successfully.
        However the UC100 instructions show a screen when you start Mach so that the UC100 can be selected. This screen doesnt appear and of course the mill doesnt work! Tried re installing everything with the same results.
        Anyone had a similar problem when using a UC100 controller?
        Peter
        #336438
        David Colwill
          @davidcolwill19261
          What state are the led's in?
          I have recently had a problem with my UC300 where on switching the PC and machine on it appeared dead. Powering both machine and PC down and rebooting solved this ( I have no idea why ).
          Make sure that the PC is connected to the internet as differences in firmware will prevent it from running, these will be corrected if there is a connection.
          Regards.
          David.
          #336440
          Involute Curve
            @involutecurve
            No experience of the UC100 but have used CNCdrives other stuff, you probably need to install an add-on for it to work, also be aware there a counterfeit ones of these knocking about apparently, below is a link to the page on there website it includes a download for the setup which presumably contains the add-on.
            HTH
            Shaun
            #336450
            John Haine
              @johnhaine32865
              I think you need to open the config menu in Mach, then select configure plugins to enable the various drivers.
              #336456
              Peter Bell
                @peterbell11509
                Thanks for the quick replies and prompts. Downloaded the automatic installer, ran it again and Mach came up with the setup screen, selected uc100 controller and the emergency stop now works!
                Nothing else works but presume I'll have to configure the outputs manually unless there's a better way of doing that? Fortunatly I kept screen shots of my previous installation.
                Peter
                #336457
                Peter Bell
                  @peterbell11509
                  Forgot to say looked in config, plugins and the uc100 box is ticked.
                  Peter
                  #336461
                  John Haine
                    @johnhaine32865
                    The only comparable experience I have is with the plugin for the XBox wireless controller. With that I find that I need to power up the controller before launching Mach3 for the latter to recognise it's connected. Have you tried powering up the UC100 before opening M3?
                    #336465
                    Peter Bell
                      @peterbell11509
                      Yes the uc100 is powered up from the usb before I open M3 but it makes no difference.
                      #344250
                      Zan
                        @zan
                        The uc100 needs a specific Mach 3 obtainable from their website. I have problems with mine with "uc100 not detected" it's been tracked down to the USB cable not being fully secure in the uc100 dongle it's a poor connection. It gets lost say every 10-15 startups
                        Check there are two LEDs lit on the dongle itself
                        Edited By Zan on 03/03/2018 18:34:41
                        #344255
                        Peter Bell
                          @peterbell11509
                          Thanks for the message.
                          My UC100 occasionally stops communicating, losing the light, normally about half way through a job.
                          Perhaps I've got the same problem, I'll have a look.
                          #344892
                          Nick Hulme
                            @nickhulme30114
                            Posted by Peter Bell on 03/03/2018 19:00:02:
                            Have you disabled all power saving for the communication port used?
                            #344931
                            Zan
                              @zan
                              No coms port, that's why I went for the uc100 which is fed by USB cable. I tried 3 port cards before splashing out on the uc, non worked due to address conflicts. In anycase coms port is obslete and if my computer gives up the ghost I'd be back to square one.
                              #356846
                              Nick Hulme
                                @nickhulme30114
                                Posted by Zan on 07/03/2018 23:56:17:
                                If you haven't dealt with all the power management settings on the USB you are ignoring the major issue with lost Communication on USB devices.
                                #356849
                                blowlamp
                                  @blowlamp
                                  Why not use the UCCNC software?
                                  Martin.
                                  #356852
                                    Don't have the device or Mach3 but notice the blurb mentions that it installs from disk in the event there's no internet connection. My experience of 'version on disk' installs is that they're often badly out-of-date compared with an internet download. If not already up-to-date, try reinstalling with an internet connection.
                                    May be worth describing the problem again. The first post says 'the mill doesnt work!' implying total failure to launch, which points to an install issue. Later you say 'My UC100 occasionally stops communicating, losing the light, normally about half way through a job'; that sounds more like hardware problem or version mismatch.
                                    Well worth giving all the USB connections a wiggle; some connectors and cables go intermittent. If they misbehave, it's possible to leave the computer / hub / dongle / device combination deadlocked. The cure is to switch everything off and start again. Best to replace any dodgy parts if you can identify them!
                                    John Haine
                                      @johnhaine32865
                                      As some people with UC100 experience contribute to this thread I thought I would pose my questions here – apologies for hijacking it! You can probably tell I have also posted elsewhere, on mycncuk and cnczone, and asked the supplier, and generally had positive responses.
                                      So, I'm finally upgrading my workhorse office laptop and will have an old but functional Dell Latitude Win 7 machine spare as a result. In the workshop the CNC machines are controlled by an even more venerable Dell WinXP desktop through the parallel port, and I'm wondering about moving the laptop to the workshop and replacing the XP machine, controlling the machines using a USB motion controller. I aim to stick with Mach 3 because it works, I understand it reasonably well, and I've written some useful extra macros for tool setting. I'm interested in people's experience to help with this decision. Another option, though more expensive, would be an Ethernet controller.
                                      1. Will the UC100 work OK with a Win 7 laptop (obviously I'm no longer using a parallel port and would need the appropriate plugins)?
                                      2. Does the UC100 support the probing input properly? That's very important for me for tool setting, for both mill and lathe.
                                      3. If I decide to ditch Mach 3 at some stage, has anyone experience of the UC100 with other CNC packages such as Mach 4?
                                      Thanks in advance for any help.
                                      #384309
                                      GoCreate
                                        @gocreate
                                        I'm using a uc300 with mach 3 on a windows 7 desktop computer. I had consistent problems with the UC300 disconnecting in the middle of a job and tried all sorts to resolve it. Then i realised the problem only occurred when I had the radio on, never had any problem since having the radio off while the cnc is running.
                                        At first I thought it might be coincidence but after many months of reliable operation it seems to have been the problem. Presumably the radio is putting out some electrical noise.
                                        Probably not related to your problem but thought I'd mention it.
                                        Nigel
                                        Edited By tractionengine42 on 07/12/2018 10:49:12
                                        #384341
                                        simon Hewitt 1
                                          @simonhewitt1
                                          John Haine:
                                          I am building a CNC with Mach4 and UC300. So far I have the software installed, with the same problems listed above, you have to tick UC300 plugin before it is visible as a motion controller. No further yet, at present I am soldering up all the cables, should be ready to get an axis to move this weekend.
                                          So far Mach4 looks 'nicer' . My main reason is I hate VB and want to learn Lua!
