Posted by JasonB on 24/04/2019 09:08:39:
Did you get your touch screen up and running Steve?
I did use Cut2D for the first few test items but have not used it for any actual parts. agree it is quite easy to get the hang of but I have not found F360 CAM any harder to pick up and that is what I'm using now. As it imports a STEP file you get heights which you don't when using a DXF in Cut2D and no need to join all those vectors together.
HI Jason,
Got too absorbed with the KX1
You are right, the 16:9 ratio screen works well, but using a 23 inch monitor I already had. The Mach3 screens are properly proportioned and there is plenty of room for the Jog flyout. I've a bit of sorting out to do then I will move onto a touch screen.
I've cut quite a few things using CUT2D, I've just cut some holes in a case and have screws in different planes interfering , which wasn't obvious until I machined them! So I could do with a package which will show all features before generating the toolpaths.
The KX1 is really sweet, wish I'd got one years ago! A few trivial bugs the max spindle speed was set at 5,000 rpm, which I've now reset to 7,000 rpm as per spec.
One thing I'm not comfortable with yet is working out plunge rates and suspect I'm being a bit too gentle!
Steve
