M5 x 0.5 threaded bar supplier
Home Forums 3D Printers and 3D Printing M5 x 0.5 threaded bar supplier
  • #31576
    Andy Carruthers
      @andycarruthers33275
      Andy Carruthers
        Can anyone recommend a supplier of M5 x 0.5 pitch threaded bar and nuts? brass or stainless steel, to repair a 3D printer, ideally up to 500mm long
        #372277
        charadam
          @charadam
          A search for stainless 5mm studding on Ebay brings over 3000 hits.
          #372278
          Bill Phinn
            @billphinn90025
            #372279
            peak4
              @peak4
              So do I, but unfortunately M5 x0.5mm pitch is metric fine.
              Assuming you have a lathe, how about a slightly off-beat method of making some.
              I've never tried this;
              Two obvious issues with threading long bar are, manually threading- the die can easily run off, and for many lathe's there's no through hole in the tailstock.
              How about quickly knocking up a die holder for use in the 3/4 jaw chuck and feeding the 5mm bar in from the tailstock direction, rather than vice versa, as normal practice.
              To hold the 5mm bar, maybe use a small boring bar holder on the cross slide toolpost; that way you could have just a bit protruding in the direction of the headstock, and keep re-positioning the toolpost along the bar as the job progresses.
              Bill
              Edited By peak4 on 18/09/2018 23:33:47
              #372280
              Frances IoM
                @francesiom58905
                0.5mm thread is ISO M5 fine – the usual Tool station etc threads are ISO coarse 0.8mm thread – I can’t recall any fine threads in their collection. Suspect you need a more specialised supplier.
                Edited By Frances IoM on 18/09/2018 23:24:17
                #372281
                Bill Phinn
                  @billphinn90025
                  Yes, Bill, it was sloppy of me not to read things more carefully.
                  How about this? (It doesn't give the pitch though.)
                  https://www.ebay.co.uk/itm/3D-Printer-5mm-Threaded-Steel-Rod-Cut-to-Custom-Lengths-M5-Bar-Shaft/191065265336?hash=item2c7c6094b8%3Am%3Am4_BexbsCwa281GHDcTGaAQ&var=490261409733
                  #372282
                  Andy Carruthers
                    Thanks to all for the suggestions – I've spent hours looking for a supplier and called a few
                    To your point Bill, I have ordered a couple of M5 x 0.5 dies to thread my own bar as a last resort – I do like your idea too!
                    #372283
                    Andy Carruthers
                      @Bill – you posted just before my response
                      I know Darren @WeDo3DPrinting and he is on my list of contacts to call tomorrow
                      #372286
                      duncan webster 1
                        @duncanwebster1
                        make a die holder to go in the toolpost and then you can power feed the die at the right pitch. Relying on the die self feeding will guarantee pitch error which might or might not matter. If you have a travelling steady you could screwcut it down to say 3/4 depth then finish with die
                        Edited By duncan webster on 19/09/2018 00:43:29
                        #372287
                        Adam Stevenson
                          @adamstevenson91624
                          Had to buy some M6 ISO fine bar 300mm long in brass about a year back and used GWR Precision Limited they don't list M5x0.5 but they will make it. Cost about £7 for each piece but I couldn't buy the brass for that.
                          #372292
                          not done it yet
                            @notdoneityet
                            Duncan’s suggestion of travelling steady followed by a die to clean up the cut to size would be my favoured method.
                            I would expect that Sterling Bolt and Nut Co Ltd in Peterborough could source it. Not the cheapest option, mind.
                            #372306
                            John Haine
                              @johnhaine32865
                              If you are looking for m5 studding and nuts, why don't you just use standard M5? Or is this for a feed screw?
                              #372320
                              peak4
                                @peak4
                                Just re-read my reply and seem to have a grocer's apostrophe blush
                                Re Bill's post previously about the ebay studding; on the page, the vendor refers to nuts also being available, and on the nuts page he has the following comment
                                High quality M5 Nuts Standard thread as used in many 3D printers
                                Bill
                                Edited By peak4 on 19/09/2018 10:48:12
                                Edited By peak4 on 19/09/2018 10:48:51
                                #372335
                                Juddy
                                  @juddy
                                  This place supplies up to 300mm lengths could be worth asking if they can supply longer:
                                  Clive Hartland
                                    @clivehartland94829
                                    I would think a thread die cut rod would be a bit sharp for a lead screw application, a rolled thread would be preferable.
                                    #372439
                                    Andy Carruthers
                                      Juddy has the right answer the owner makes the threaded rods himself so they are not cheap, incidentally he makes them for CEL Robox 3D printer upgrades which is exactly what I am looking for
                                      Thanks again to all
