M3 (5.5) flat spanners
Home Forums Workshop Tools and Tooling M3 (5.5) flat spanners
Viewing 21 posts - 1 through 21 (of 21 total)
  • #623777
    Rod Ashton
      @rodashton53132
      Having trouble sourcing M3 (5,5) simple flat spanners. Been on the net for some time and cannot find either single spanners or even single 3&4 mm double ended. Except in one case and they where out of stock.
      Please offer me your source if you should have found one.
      Rod Ashton
        @rodashton53132
        #623778
        jimmy b
          @jimmyb
          Rod,
          ebay has them, just search for 5.5mm spanner.
          Jim
          #623782
            The Proxxon ones are quite nice, I tend to use the combination but they also do flat, Axminster sell them both. I think they may be branded Elora ones as they are so similar.
            Elora also do an right angled ended one which can be useful at times
            Edited By JasonB on 06/12/2022 07:35:56
            #623783
            Martin Connelly
              @martinconnelly55370
              I needed a spanner to do up some M2.5 nuts a few weeks ago. I have a suitable box driver but could not use it due to poor access. I cut one out of a piece of old bandsaw blade with a Dremel and stoned the outside edges for comfort. It is not pretty but it works.
              Martin C
              #623785
              DC31k
                @dc31k
                Posted by Rod Ashton on 06/12/2022 06:55:00:
                'Draper Elora midget double open ended spanner' are the magic words today.
                https://www.drapertools.com/hand-tools/spanners/open-ended-spanners/
                3mm a/f does seem a little hard to find.
                #623786
                HOWARDT
                  @howardt
                  I bought a set from Amazon, cheap but work ok, go through M2 to M5. Also have a set of nut spinners which are better for small sizes when you have good face access.
                  #623787
                    Posted by DC31k on 06/12/2022 08:15:13:
                    He wants 5.5mm AF to fit M3, so assume a 5.5/7 for M3/M4 is what was meant
                    Edited By JasonB on 06/12/2022 08:44:13
                    #623788
                    Rod Ashton
                      @rodashton53132
                      Sorry gentlemen. Should have searched for 5.5 a/f not 3mm. My bad.
                      #623789
                      David Ambrose
                        @davidambrose86182
                        Model Engineers Laser do various sets of small spanners.
                        #623794
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, I agree with JasonB about the right angle ended spanners being useful, I bought an unbranded set of eight, ranging from 5mm to 11mm, including a 5.5mm one, from a street trader, probably about 25 years ago and have use them many times over the years. They were quite cheap at the time, compared to similar sized normal open-ended spanners found in local hardware stores, but are of good quality and have a nice user profile which reminds me of the old Britool style.
                          Regards Nick.
                          #623797
                          Kiwi Bloke
                            @kiwibloke62605
                            Modelfixings  **LINK** list open-ended and combination spanners in these small sizes – although the 5 X 5.5 open-ended is currently out of stock. I have no connection with this company, but was about to place an order, including these little spanners, but, with the postal strike and Xmas chaos looming, will wait 'til all the hullabaloo is over…
                            Edited By Kiwi Bloke on 06/12/2022 09:34:11
                            #623800
                            Nigel Bennett
                              @nigelbennett69913
                              5BA spanners are readily available and will probably do the job at a nominal 5.58mm AF.
                              #623803
                              DC31k
                                @dc31k
                                Posted by JasonB on 06/12/2022 08:42:09:
                                It's an interesting problem in stock optimisation or marketing.
                                If you start with 19-17 (M12/M10) and go downwards, the next would be 13-10, 8-7, 5.5-??
                                At the low end, do you include the half mm sizes, skip them or have a special spanner that is only for half mm sizes?
                                Looking at:
                                https://www.slsbearings.com/slsbnn/spanner.html
                                I wonder why Draper do the 3mm A/F one at all as it looks like M1.6 is 3.2mm.
                                If you had 5.5-7, what would the rest of the range look like? Do you go 19-22 (for M14 that is rare) or 19-24?
                                #623811
                                Nick Clarke 3
                                  @nickclarke3
                                  For occasional use the laser cut BA/Metric sets from Blackgates are great value but separating them from the sprue (they are laser cut as one and look like bits of an Airfix model) can be a bit long.
                                  At under a tenner for something rarely used can't be beaten.
                                  #623819
                                    You can get the 5.5 / 7 pair easy enough from makers they also do 6, 9, etc AF for those that may have a need, handy when you get say an M8 with 12 or 14AF which is quite common
                                    #623837
                                    Juddy
                                      @juddy
                                      #623845
                                      File Handle
                                        @filehandle
                                        Some time ago I bought a 5 / 5.5 Proxxon from a hardware store in York. Sadly they never replaced the stock and have switched to Draper, but stop at 6. My nut spinners, box of small BA, Imperial metric spanners normally get me by, but there is also a couple of tiny adjustables in there as well.
                                        I guess those of us that use small spanners are in a small minority now as sops don't seem to stock much below 6mm. Although interestingly they do sell nuts and bolts (screws) with small heads.
                                        #623867
                                        Dave S
                                          @daves59043
                                          Pimoroni do this nice looking set:
                                          Engineer® Combination Spanner Set
                                          Hollowpoint
                                            @hollowpoint
                                            I have the "Engineer super slim" spanner set posted above by Dave S. Though they are just cut from sheet steel they are surprisingly nice quality (made in Japan) and the super low profile makes them extremely useful.
                                            #623900
                                            Steve Neighbour
                                              @steveneighbour43428
                                              Also these on eBay
                                              Model Makers 10pc Mini Small Size Spanner Wrench Set Combination 4.0-11mm
                                              Edited By Steve Neighbour on 07/12/2022 11:02:53
