M10 x 1.0 Fine
M10 x 1.0 Fine
Home Forums The Tea Room M10 x 1.0 Fine
Viewing 25 posts - 1 through 25 (of 31 total)
  • #627005
    Vic
      @vic
      I have a small project planned that requires a spring to be retained by an M10 “threaded object”. cheeky I discovered some time ago how much nicer and easier it is to produce fine threads in M10 and M12 so I hoped to use M10 x1.0. I normally get my fasteners on the auction site but I’ve found it very difficult to get anything in that size and pitch except for bolts which are far too long or shipped from China.
      I then happened upon these. I’m hoping they do the job and lock in place nicely without thread lock etc. Not so expensive that I can’t put it down to experience if they don’t work as intended. I didn’t realise that M10 x 1.0 fasteners were so rare, I’ll have to buy an M10 x 1.25 tap I suppose for future projects. wink
      Vic
        @vic
        #627011
        noel shelley
          @noelshelley55608
          10 x 1 was/ is a common thread for lamp holders, the fitting is often brass. 8 x 1 is also not uncommon. Noel.
          #627012
          Vic
            @vic
            I succumbed and ordered some M10 x 1.0 stainless socket screws from China. They are cheap enough but not due to arrive until the second week of February – and that obviously dependent on RM strikes.
            #627014
            Pete Rimmer
              @peterimmer30576
              M10x1 is spark plug thread, so finding a tap should be easy.
              If I have to buy on-off taps or dies I usually go to Tracy Tools first.
              #627015
              John Hinkley
                @johnhinkley26699
                Vic,
                That offer is for taper thread plugs. Is that what you are after? I would have thought that a spring retainer would need a parallel thread.
                #627018
                Ex contributor
                  @mgnbuk
                  Standard M10 Coarse thread is 1.5 pitch, not 1.25 ?
                  I have only come across M10 x 1 (and M8 x 1) for hydraulic fittings, hence the tapered pipe plugs you show a listing for. IIRC the last M10x1 pipe plugs I ordered were for blanking an outlet on a VW Type 2 master cylinder. M8x1 is a standard size used on lubrication fittings for central lube system restrictors.
                  Nigel B.
                  #627019
                  bernard towers
                    @bernardtowers37738
                    Noel, Im surprised by what you say about lamp fittings as I have always used 3/8 BSB?
                    #627021
                    Frances IoM
                      @francesiom58905
                      the 1mm thread seems very common in many electronic related items – anything from 8mm upwards
                      0.75mm thread also seems commonly used for small items.
                      #627025
                      Vic
                        @vic
                        Posted by John Hinkley on 01/01/2023 11:23:48:
                        Vic,
                        Yes I know, as I mentioned no big deal if it doesn’t work out.
                        Posted by Pete Rimmer on 01/01/2023 11:20:23:
                        I already have a couple of taps in that size.
                        #627026
                        Martin Kyte
                          @martinkyte99762
                          Posted by bernard towers on 01/01/2023 11:41:48:
                          That would be British Standard Bulb then 😊
                          #627027
                          Vic
                            @vic
                            Posted by mgnbuk on 01/01/2023 11:38:24:
                            Nigel B.
                            Yes I know, I’ve got standard Metric coarse. As I said in my OP I find cutting fine threads in the larger sizes much easier and for my application more than adequate. Now I know 1.0 is not so common I need to get a 1.25 Tap and probably a Die.
                            #627028
                            peak4
                              @peak4
                              #627029
                              martin haysom
                                @martinhaysom48469
                                i just "googled" 10 x 1mm tap and die lots to chose from
                                #627032
                                  Not hard to use a die or screwcut a bit of 10mm bar to M10 x 1, put a slot in the end or mill a square "head" and just screw that into your m10 x 1 hole.
                                  1/8" BSP is a similar overall diameter easy to cut thread and plenty of plugs about in that thread size.
                                  #627037
                                  noel shelley
                                    @noelshelley55608
                                    10 out of 10 Martin ! Bernard, in Norfolk 25.4 or 26 would be near enough, just tighten with the 24"stilsons ! Noel.
                                    #627044
                                    Nick Wheeler
                                      @nickwheeler
                                      M10x1 is actually very, very common. Walk outside, and pretty much every car you see will have a couple of dozen of them in the brake and clutch plumbing. Mazda use it for a number of mechanical parts on MX5s – so much so that I bought a tap for modifying them to fit a friend's kitcar project.
                                      Similarly, M12x1.5 has been a common wheel bolt and fuel fitting thread for decades, even though it is considered odd in 'normal' engineering
                                      #627053
                                      old mart
                                        @oldmart
                                        I had no problems getting hold of M10 x 1 bolts and a tap when we remade the X axis stops on the drill mill. 1mm pitch was chosen because the mill is metric and it would be easy to make engraved dials for fine adjustment.
                                        #627130
                                        Vic
                                          @vic
                                          Posted by martin haysom on 01/01/2023 12:42:03:
                                          Yes the taps are easy to find. At least they were when I bought mine. It’s finding the bolts that’s not so easy.
                                          The problem with some suppliers are the shipping costs. Lots of suppliers fail to get my business due to this.
                                          #627131
                                          Vic
                                            @vic
                                            They look nice, but the postage is 2 1/2 times the cost of the bolts. 😉
                                            #627135
                                            peak4
                                              @peak4
                                              Posted by Vic on 01/01/2023 22:00:50:
                                              I've not looked today, but they regularly have good stuff on offer, which can go into stock to get above minimum order for free postage.
                                              Check out imperial silver steel, which is what I ordered last time.
                                              2m lengths were cheaper than 1m ones in some sizes.
                                              Bill
                                              #627138
                                              Nick Wheeler
                                                @nickwheeler
                                                Don't you have a fastener supplier near you that sells small quantities?
                                                #627139
                                                Hopper
                                                  @hopper
                                                  Would 't it be much easier to use a standard sized thread and readily available fasteners to suit?
                                                  Bolts in M10 x 1.25 or 1.5 are common as muck.
                                                  Cutting a 10mm thread of any pitch with a tap should not be difficult. The finer pitch should not make a noticeable difference in effort to cut the thread. And obviously the faff to get bolts to fit the 1.0 pitch outweighs the effort saved, if there is any.
                                                  If you are finding an M10 x 1.25 or 1.5 thread difficult to cut with a tap, most likely you need to drill the tapping hole a bit bigger. See Tubal Cain's Model Engineer's Handbook for just how much oversize you can go and still retain 95 per cent of the thread strength. Down to 65 per cent thread engagement will give this rating.
                                                  Make life easy for yourself. That's my motto.
                                                  #627143
                                                  jimmy b
                                                    @jimmyb
                                                    Vic,
                                                    Message sent.
                                                    Jim
                                                    #627157
                                                    Nick Clarke 3
                                                      @nickclarke3
                                                      The most common 'odd' thread I have come across is M3.5 as used for electrical switches and sockets.
                                                      In theory an ideal replacement for 4ba but not easy to find and often expensive.
